[Release] PVR EON.tv
  • mel42, stoynoff,
    obviously something is not working for other providers.
    In order to find the missing pieces following things would be helpful:
    1) debug [definition='1','0']log[/definition]
    2) which fields in the setting.xml are filled (except username and password)
    3) best would be if I could get temporary access to an account. Send me PM in case of interest
  • mel42
    1. Install addon 'Kodi Logfile Uploader'
    2. activate 'debug logging' in settings, system, protocol
    3. restart Kodi
    4. reproduce the error
    5. run the 'Kodi Logfile Uploader' from addons and post the url from paste.kodi.tv
  • These is the relevant part from installation:
    It seems that a installation failed indeed. Below in [definition='1','0']log[/definition] there's no pvr.eon installed. Notice that you have a bunch of banned addons/repos installed (look yourself into the [definition='1','0']log[/definition] and see all entries marked red). I suggest to start with a fresh install wihout those suspicious addons/repos.
  • Good day PVD. THanks for your efforts. I have already started a fresh install with the official kodi 20.1 . Can you please advise which is the last version of kodi nerds for android shield tv pro device ? If there is any new version of the eon addon in the future i will be happy to test it .
  • webmaher
    Thank you for the [definition='1','0']log[/definition]. The API does not accept username / password. Did you double check that they are correct and without blanks? And that you are not hitting the limit of max devices? I assume so. If that is true I need to enhance the logs with more details.
  • Thanks Nirvana777 it works... i already have 5 devices... its only one problem..when switching channels it took 15-20 seconds... first i see black screen and then No signal message ... i try to change some settings but no success... maybe my Beelink GT 1 is to old (Android 7.1.2)... is any chance to also have windows addon and of course VOD...
  • Great - then we have confirmation from Slovenia, Bulgaria and Bosnia that it is working. Missing still SBB/Serbia and Nova/Greece if I am not mistaken.
    - Windows should be possible but someone needs to compile the addon.
    - VOD would be plugin.video. This cannot be integrated into a PVR addon. PVR is for LiveTV and Replay/Restart only in Kodi.
