Need help with washed out Dolby Vision
  • Hey just got my shield pro set and ready to use kodinerds maven21 with the crew and other add ones, but I've noticed that whenever Dolby Vision comes on it very washed out compared to the same content in HDR. Is there any way to fix this? Everything that pops up when I google the issue is from multiple years ago and most of the doesnt help. I'd really appreciate if someone could point me in the right direction here
    Nvidia Shield pro 2019
    Kodinerds maven 21.2
    The Crew
    Lg G3 oled
  • You should adjust Black Levels on Your LG G3 OLED. Manually tweak your black level, brightness, or contrast settings to compensate for the washed-out appearance. If possible, access sources like The Crew, Netflix, or Prime directly via the LG TV’s built-in apps rather than through Kodi/Maven. These often handle DV more accurately.
