Ne, ohne CH-IP kommt bei mir ein 403 Forbidden.
Telerising API - Zattoo, blue TV & Sky CH für tvHeadend und VLC [Web App]
easy4me -
26. Februar 2021 um 21:21 -
läuft hier ich benutze eine abgespeckte Version (nur Sender von Interesse)
Alles anzeigen#EXTM3U #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1010", ORF 1 HD https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1010/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1009", SRF zwei HD https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1009/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1052", SRF info HD https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1052/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1013", 3+ https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1013/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1031", 4+ https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1031/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1047", 5+ https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1047/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1154", 6+ https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1154/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1053", Puls8 https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1053/index.m3u8?content_location=x-poseidon #KODIPROP:inputstreamclass=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #EXTINF:0001 tvg-logo="https://web.netstream.tv/fb/channel-logo/1012", ServusTV HD https://netstream-hls.customers.xcdn.iptv.ch/v1/hls/ott/tv/1/1012/index.m3u8?content_location=x-poseidon
Und was wird dir dort angezeigt? Würde mich mal interessieren.
Sehr geheimnisvoll, unter Vodafone läuft da gar nichts.
Guten Morgen, die fehlenden e01-e05 hat DNS4.. über Nacht nachgelegt, jetzt funktioniert es wieder.
Beste Grüße
Beste Grüße
Kann ich bestätigen. Sind wieder hinterlegt und Netstream als auch die Wilma Free Streams über netstream laufen wieder auch bei mir. Thx!
Bei mir der Ort meines lokalen Netzknotens. Also Deutschland. Netstream läuft aber.
Hier eine Info für DNS4me-Nutzer: Ich haben bei dns4me angefragt, warum man keine custom domains für die Schweiz mehr erstellen kann. Als Grund erhielt ich die Auskunft, dass sie diese Option wegen Missbrauchsbeschwerden entfernen mussten. Mit der Anwahl von Zattoo -> Schweiz werden aber ab heute automatisch folgende Adressen der Schweiz mitzugeordnet:
3-zurich.s3.netstream.cloud
web.netstream.tv
e01-ch-dub-1.xcdn.iptv.ch
e02-ch-dub-1.xcdn.iptv.ch
e03-ch-dub-1.xcdn.iptv.ch
e04-ch-dub-1.xcdn.iptv.ch
e05-ch-dub-1.xcdn.iptv.ch
netstream-ott.customers.xcdn.iptv.ch
netstream-hls.customers.xcdn.iptv.ch -
Ist ja nicht so, dass es in den letzten Beiträgen genau darum ging...
netstream-dash.customers.xcdn.iptv.ch fehlt übrigens für Netstream Dash.
Der Netstream Dash Stream wurde auch am Donnerstag/Freitag durch unsere (herbertdererste/meiner Person) Tickets mit den beiden anderen ott/hls schon ergänzt. Sollte somit alles weiterhin via DNS4ME was benötigt wird geroutet werden.
Feature Idee: Könntest du eine weitere Einstellung http proxy hinzufügen? Und entsprechend optional in den gepipeten URLs für ffmpeg die Option -http_proxy <PROXY> mitgeben?
Das würde mir reichen. Natürlich könnte Telerising selbst auch die Einstellung befolgen, wäre mir aber nicht wichtig.
Grüße
Meines Erachtens habe ich hier schon mal erwähnt, dass Netzwerkumleitungen via VPN/Proxy nicht zu den Aufgaben von Telerising gehören.
Grüße
Vor allem denke ich nicht, dass es klappen würde, da die Option http_proxy von ffmpeg keine https Verbindungen herstellt.
Hallo zusammen,
immer nach etwa fast exakt 2 Stunden hängt der Stream immer, egal ob HLS/DASH, egal welcher Sender.
An Kodi liegt es nicht, habe das Problem auch mit Wiedergabe in VLC.
Kurzes Sender Stoppen und wieder starten und dann kann man wieder 2 Stunden ohne Probleme Streamen.
Hatte das Problem schon mal jemand anderes?
Scheinbar nicht. Ich weiß noch nicht mal, um welche Quelle (Zattoo/Sky CH/blue TV) es jetzt geht.
Oh ja sorry, aktuell nutze ich yallo. Full Hd, dash in tvheadend 4.3. Etwa nach 2-3 Stunden wie gesagt das beschriebene Problem.
Wie sieht es denn auf der offiziellen Yallo-Webseite aus?
das kann ich leider nicht sagen, ich spiele alles direkt auf dem VPS ab über tvheadend. (Linux, keine Gui vorhanden)
Kann ja dann auch am VPS liegen.
Okay. Ich wandele meine Feature Idee ab: Ein Freifeld: "additional URL-Parameter" würde mir auch reichen.
(Du muss hierauf nicht eingehen - alles gut)
Falsch!
