My SonOff switch is unreachable with kodi 18.1
  • Access the switch through web again and tell me about:
    • type of switch you have set
    • firmware version
    • enable Belkin Wemo emulation
    from kodi provide a [definition=12,1]debug-log[/definition] pls.
  • Is there any issue with Hostname in sonoff configuration?
    No. The addon use the ip of the sonoff(s). Hostname is ignored
  • There's something wrong with your firmware. The actual version is 6.4.1. For update see: https://github.com/arendst/Sonoff-Tasmota/releases
  • Now will go to next step with Alexa
    If you scan for new devices in Alexa, you will see belkin switches. You can set a friendly name within the sonoff interface. This is the calling name for the switch in in Alexa. Sometimes it is necessary to repeat the scan if Alexa don't find devices.
