Maven's Kodi-Builds für Android
  • Hi, hope English messages are ok. I'm using Google translate to learn from these forums.
    I was wondering if I can use Mavens Kodi on my Sony TV XH9505, so I can get Dolby Vision to work, as the original Kodi doesnt work well with DV?
    If I can, which is the latest version that will work?
    Two have nexus and two have matrix in their filenames, but the titles are different, sorry a little confused.
    Thank you
  • Wo kann ich diese Versionen herunterladen?
  • https://repo.kodinerds.net/
    Oben in der Leiste Nerds Rero
  • Interessant finde ich das ihr auch mit der 64bit Version solche Probleme habt.
    Ich habe seit dem shield 9.02 Update mit KODi 19.4 32bit diese Problematik bei HDR Dolby Vision Atmos - Bild und Tonausetzer etc.
    Ist das Problem mit maven builds mittlerweile gelöst?
  • Dear All,
    I have a fire stick 4k max and im confused a little bit.
    Could you advise me what is the exact difference between the releases this below?
    net.kodinerds.maven.kodi.armeabi-v7a-202206140017-1c1a3b96-Matrix.apk
    Maven's Kodi-Builds für FireTV
    net.kodinerds.maven.kodi.firetv.armeabi-v7a-202206132218-75b5c746-Matrix.apk
    I just asking this because as (until now) i can see the android version works also on the fire tv stick and with that i have a working dolby vision support.
    On the other hand i have no dolby vision with the latest fire tv version.
    Please help which version should i use on my fire tv stick, for example what is the advantage of the fire tv apk compared to the android version?
    The another question would be , is the nexus version ok to for everyday use yet, or still better to stay on matrix? (would be nice to have working dolby vision)
    Thanks for your help!
  • Guten Morgen zusammen,
    ich möchte gerne die Maven Kodi Build auf meinen Sony TV nutzen. Ist das Modell XR75X94J
    Leider kann ich irgendwie keine Version hier raufspielen, extra dafür SolidExplorer auf dem TV installiert und rechte sind für die Paketinstallation gegeben. Trotzdem mag er nicht.
    Android 10 läuft auf dem TV.
    Was kann ich tun am besten? Welche Android Version brauche ich von der MAven Build, v7a , v8a 64??
    Danke euch
  • Hallo dextermorgan
    ich rate mal nicht genug Speicherplatz?
    mal mit adbLink probiert?
    Ich habe einen Fire Stick 4k max und bin ein wenig verwirrt.
    Könnt ihr mir sagen, was der genaue Unterschied zwischen den folgenden Versionen ist?
    Ich frage das nur, weil ich (bis jetzt) sehen kann, dass die Android-Version auch auf dem Fire TV Stick funktioniert und ich damit eine funktionierende Dolby Vision Unterstützung habe.
    Auf der anderen Seite habe ich keine dolby vision mit der neuesten fire tv Version.
    Bitte helfen Sie mir, welche Version sollte ich auf meinem fire tv stick verwenden, zum Beispiel, was ist der Vorteil der fire tv apk im Vergleich zur android Version?
    Die andere Frage wäre, ist die nexus Version ok für den alltäglichen Gebrauch, oder immer noch besser, auf Matrix zu bleiben? (es wäre schön, wenn Dolby Vision funktionieren würde)
    Vielen Dank für eure Hilfe!
    Übersetzt mit http://www.DeepL.com/Translator (kostenlose Version)
    Zuerst, verzeihen sie mir meine schlechte deutsch.
    Ich sehe dass ich auf dem schlechten teil des foren.
    Meine ausruestung : Shield Pro 2019 (9.0.2) direkt zum Samsung Q950A und dann zu meinem TV 65Oled855.
    Seit einigen versionen von Maven's Kodis arm64-v8a, ich habe bemerkt dass die audiospuren haben eine luecke von ca. 200 ms.
    Besonders mit True-HD Atmos.
    Mit Kodi Fandangos (matrix 19.0) habe ich kein probleme, die audio ist perfekt mit die bildern abgestimmt.
    Haben sie auch dass bemerkt ? Wenn's nicht was ist falsch bei mir ?
  • Dear All,
    I would like to ask your help.
    I have an Ugoos am6b plus 2021 box with Android 9 and installed with Maven's Kodi-Builds für Android armeabi-v7a 202206140017-1c1a3b...
    I experience an issue but based on logs it seems to be 2 different problems:
    - Randomly the movies are not starting to play, it changes the refresh rate on start, but instead of playing movie i see the 'loading icon spinning'.
    This happens with different kind of movies, mp4, mkvs (4k, 1080p, HDR, DV, no HDR, no DV etc).
    I am working on to get out the details from the logs, but not that simple :)
    So far this is what i have found:
    The second version:
    2022-06-19 17:01:39.480 T:17376   DEBUG <general>: CFileCache::Process - <smb://192.168.0.89/@_filmek/@_HD_Filmek/Sonic.the.Hedgehog.2.2022.2160p.WEB-DL.Dolby.Vision.SL.DDP.5.1.Atmos.h265-HUN-UFO971/Sonic.the.Hedgehog.2.2022.2160p.DV.SL.UFO971.mp4> cache completely reset for seek to position 4511027287
    2022-06-19 17:01:39.498 T:17275   ERROR <general>: ffmpeg[0x88f06840X]: [hevc] PPS id out of range: 0
    2022-06-19 17:01:39.498 T:17275   DEBUG <general>: ffmpeg[0x88f06840X]: [hevc] Error parsing NAL unit #2.
    2022-06-19 17:01:39.499 T:17275   ERROR <general>: ffmpeg[0x88f06840X]: [hevc] PPS id out of range: 0
    2022-06-19 17:01:39.499 T:17275   DEBUG <general>: ffmpeg[0x88f06840X]: [hevc] Error parsing NAL unit #0.
    2022-06-19 17:01:39.500 T:17275   ERROR <general>: ffmpeg[0x88f06840X]: [hevc] PPS id out of range: 0
    2022-06-19 17:01:39.500 T:17275   DEBUG <general>: ffmpeg[0x88f06840X]: [hevc] Error parsing NAL unit #0.
    2022-06-19 17:01:39.501 T:17275   ERROR <general>: ffmpeg[0x88f06840X]: [hevc] PPS id out of range: 0
    When i have this problem, i have to stop 2-4 times and start again and then start to play it.
    Any ideas how to fix it?
    I hope i have asked it in the right forum :)
    Thanks,
    Br,
    Janaboy
  • moin moin
    Ich wollte jetzt endlich mal von meiner 19.1 auf die aktuelle Version upgraden.
    Die Version 19.1 wurde damals in den ordner org.xbmc.kodinerds installiert.
    Die aktuelle installiert sich in den Ordner net.kodinerds.maven.kodi.
    Um mir ein wenig arbeit und Zeit zu ersparen, wollte ich alles vom alten Userdata Oder in den neuen kopieren.
    Auch den Thumbnails Ordner, denn da sind tausende von Bildern drin.
    Geht das so, sollte ich noch was beachten ?
    Ich bin mir zb unsicher, ob ich die addon_data einfach so einfach kopieren kann.
    Mediaplayer: Nvidia Shield 2019 Pro, Nvidia Shield 2015, Zotac ID91, FireTV 4K
    Kodi v21 Omega mit MySQL Datenbank & Estuary Mod V2
    TV: LG 55" 4K
    DS916+ DSM 6.x mit 3x6TB intern und 1x 3TB extern, DSM 6.x
    DS418 DSM 6.x mit 2x6TB
    DS215j DSM 6.x mit 2x2TB intern und 1x 2TB extern
    Router: Fritzbox 7590 & Mesh 2400
    AP: Vigor AP902, 3xTP-Link TL-SG2008 (managed)
  • ok, die Frage hat sich erledigt.
    Ich konnte eigentlich alles weiter benutzen bis auf das addon Verzeichnis.
    Bis jetzt läuft alles. Auch das rar-archive plugin.
    Edit: Läuft doch nicht. Das Scannen nach neuen Filmen/Serien wird abgebrochen. rar-archive Error kommt weiterhin.
    Edit2: Ich hatte noch einen Settingfehler drin. Ich denke jetzt läuft alles bis auf die Fehlermeldung vom Plugin rar-archive. Das nervt etwas.
    TV: LG 55" 4K
    2 Mal editiert, zuletzt von BrainBug (21. Juli 2022 um 10:35) aus folgendem Grund: Weitere Fehler beseitigt
  • Hi, Is the aspect ratio still a issue when playing DV content with matrix and nexus?
    Apparantly up to April 2022 Nexus was ok but I updated since and DV still a problem and I cannot download old versions of nexus or matrix, so cannot watch DV correctly.
    Thanks
