Ich weiß nicht inwieweit du das modifiziert hast, durchaus möglich das jetzt der thread check nicht funktioniert da der prozess jetzt gekillt wird.
Das musst du jetzt ausklabustern
[RELEASE] Takealug EPG Grabber - STOPPED
DeBaschdi -
8. Februar 2019 um 09:36 -
Geschlossen -
sorry leider immer noch das selbe.
Alles anzeigen-------------------------------------------- Magenta MTD XMLTV GRABBER Release v0.0.3 BETA - 2019/06/02 -------------------------------------------- Initializing script environment... Starting PHP Proxyserver for MagentaTV PHP 7.0.33-0ubuntu0.16.04.4 Development Server started at Sun Jun 2 04:25:47 2019 Listening on http://192.168.1.204:8000 Document root is /home/osboxes/tkm/server Press Ctrl-C to quit. Starting 4 WG+ Threads for faster Download Get ready to RUMBLE!!! WebGrab+Plus/w MDB & REX Postprocess -- version V2.1.5 Jan van Straaten Francis De Paemeleere thanks to Paul Weterings and all the contributing users -------------------------------------------------------------------------------- Job started at 02/06/2019 04:25:55 WebGrab+Plus/w MDB & REX Postprocess -- version V2.1.5 Jan van Straaten Francis De Paemeleere thanks to Paul Weterings and all the contributing users -------------------------------------------------------------------------------- Job started at 02/06/2019 04:25:55 WebGrab+Plus/w MDB & REX Postprocess -- version V2.1.5 Jan van Straaten Francis De Paemeleere thanks to Paul Weterings and all the contributing users -------------------------------------------------------------------------------- Job started at 02/06/2019 04:25:55 WebGrab+Plus/w MDB & REX Postprocess -- version V2.1.5 Jan van Straaten Francis De Paemeleere thanks to Paul Weterings and all the contributing users -------------------------------------------------------------------------------- Job started at 02/06/2019 04:25:55 Job finished at 02/06/2019 04:25:56 done in 0s Unhandled Exception Method 'Array.Empty' not found. at WGconsole.Program.ConsoleApplication (System.String[] args) <0x401b0000 + 0x0750f> in <filename unknown>:0 at WGconsole.Program.Main (System.String[] args) <0x401a7f60 + 0x00087> in <filename unknown>:0 For detailed info, see [definition='1','0']log[/definition] file /home/osboxes/tkm/w1/WebGrab++.[definition='1','0']log[/definition].txt Execution stopped Job finished at 02/06/2019 04:25:56 done in 0s Unhandled Exception Method 'Array.Empty' not found. at WGconsole.Program.ConsoleApplication (System.String[] args) <0x41145000 + 0x0750f> in <filename unknown>:0 at WGconsole.Program.Main (System.String[] args) <0x4113cf60 + 0x00087> in <filename unknown>:0 For detailed info, see [definition='1','0']log[/definition] file /home/osboxes/tkm/w2/WebGrab++.[definition='1','0']log[/definition].txt Execution stopped Job finished at 02/06/2019 04:25:56 done in 0s Unhandled Exception Method 'Array.Empty' not found. at WGconsole.Program.ConsoleApplication (System.String[] args) <0x41208000 + 0x0750f> in <filename unknown>:0 at WGconsole.Program.Main (System.String[] args) <0x411fff60 + 0x00087> in <filename unknown>:0 For detailed info, see [definition='1','0']log[/definition] file /home/osboxes/tkm/w3/WebGrab++.[definition='1','0']log[/definition].txt Execution stopped Job finished at 02/06/2019 04:25:56 done in 0s Unhandled Exception Method 'Array.Empty' not found. at WGconsole.Program.ConsoleApplication (System.String[] args) <0x41dee000 + 0x0750f> in <filename unknown>:0 at WGconsole.Program.Main (System.String[] args) <0x41de5f60 + 0x00087> in <filename unknown>:0 For detailed info, see [definition='1','0']log[/definition] file /home/osboxes/tkm/w4/WebGrab++.[definition='1','0']log[/definition].txt Execution stopped Webgrab is finish Stopping PHP Proxyserver for MagentaTV Start merging XMLś Copy generated XMLś in Workfolder cp: cannot stat 'w1/guide.xml': No such file or directory cp: cannot stat 'w2/guide.xml': No such file or directory cp: cannot stat 'w3/guide.xml': No such file or directory cp: cannot stat 'w4/guide.xml': No such file or directory Modyfy XMLś and Creating Index for Splitted Files sed: can't read xml/part-01.xml: No such file or directory sed: can't read xml/part-02.xml: No such file or directory sed: can't read xml/part-03.xml: No such file or directory sed: can't read xml/part-04.xml: No such file or directory sed: can't read xml/part-01.xml: No such file or directory sed: can't read xml/part-02.xml: No such file or directory sed: can't read xml/part-03.xml: No such file or directory sed: can't read xml/part-04.xml: No such file or directory Merging Guide Together cannot open sub document 'xml/part-01.xml': No such file or directory at /usr/bin/xml_merge line 71. at /usr/bin/xml_merge line 65. at /usr/bin/xml_merge line 65. Replace Channel IDś into Rytec ones --2019-06-02 04:26:01-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/channelmapper/channelmapper_rytec.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 14480 (14K) [text/plain] Saving to: ‘mapper/channelmapper_rytec.pl’ mapper/channelmappe 100%[===================>] 14.14K --.-KB/s in 0.05s 2019-06-02 04:26:01 (301 KB/s) - ‘mapper/channelmapper_rytec.pl’ saved [14480/14480] Map Genre into EIT --2019-06-02 04:26:01-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/genremapper/genremapper.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 19925 (19K) [text/plain] Saving to: ‘mapper/genremapper.pl’ mapper/genremapper. 100%[===================>] 19.46K --.-KB/s in 0.05s 2019-06-02 04:26:02 (385 KB/s) - ‘mapper/genremapper.pl’ saved [19925/19925] Start IMDB-Mapper --2019-06-02 04:26:02-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/age.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 1018 [text/plain] Saving to: ‘imdb/age.php’ imdb/age.php 100%[===================>] 1018 --.-KB/s in 0s 2019-06-02 04:26:02 (269 MB/s) - ‘imdb/age.php’ saved [1018/1018] --2019-06-02 04:26:02-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/country.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 3223 (3.1K) [text/plain] Saving to: ‘imdb/country.php’ imdb/country.php 100%[===================>] 3.15K --.-KB/s in 0s 2019-06-02 04:26:03 (80.3 MB/s) - ‘imdb/country.php’ saved [3223/3223] --2019-06-02 04:26:03-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdb.class.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 61681 (60K) [text/plain] Saving to: ‘imdb/imdb.class.php’ imdb/imdb.class.php 100%[===================>] 60.24K --.-KB/s in 0.1s 2019-06-02 04:26:03 (537 KB/s) - ‘imdb/imdb.class.php’ saved [61681/61681] --2019-06-02 04:26:03-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/run.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 35150 (34K) [text/plain] Saving to: ‘imdb/run.pl’ imdb/run.pl 100%[===================>] 34.33K --.-KB/s in 0.06s 2019-06-02 04:26:03 (530 KB/s) - ‘imdb/run.pl’ saved [35150/35150] --2019-06-02 04:26:03-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/poster.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 211 [text/plain] Saving to: ‘imdb/poster.php’ imdb/poster.php 100%[===================>] 211 --.-KB/s in 0s 2019-06-02 04:26:04 (74.0 MB/s) - ‘imdb/poster.php’ saved [211/211] --2019-06-02 04:26:04-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/rating.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 193 [text/plain] Saving to: ‘imdb/rating.php’ imdb/rating.php 100%[===================>] 193 --.-KB/s in 0s 2019-06-02 04:26:04 (62.8 MB/s) - ‘imdb/rating.php’ saved [193/193] --2019-06-02 04:26:04-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/url.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 174 [text/plain] Saving to: ‘imdb/url.php’ imdb/url.php 100%[===================>] 174 --.-KB/s in 0s 2019-06-02 04:26:04 (44.2 MB/s) - ‘imdb/url.php’ saved [174/174] --2019-06-02 04:26:04-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/year.php Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 175 [text/plain] Saving to: ‘imdb/year.php’ imdb/year.php 100%[===================>] 175 --.-KB/s in 0s 2019-06-02 04:26:05 (64.7 MB/s) - ‘imdb/year.php’ saved [175/175] --2019-06-02 04:26:05-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_1.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 25095 (25K) [text/plain] Saving to: ‘imdb/imdbtask_1.pl’ imdb/imdbtask_1.pl 100%[===================>] 24.51K --.-KB/s in 0.06s 2019-06-02 04:26:05 (430 KB/s) - ‘imdb/imdbtask_1.pl’ saved [25095/25095] --2019-06-02 04:26:05-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_2.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 25095 (25K) [text/plain] Saving to: ‘imdb/imdbtask_2.pl’ imdb/imdbtask_2.pl 100%[===================>] 24.51K --.-KB/s in 0.06s 2019-06-02 04:26:06 (428 KB/s) - ‘imdb/imdbtask_2.pl’ saved [25095/25095] --2019-06-02 04:26:06-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_3.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 25095 (25K) [text/plain] Saving to: ‘imdb/imdbtask_3.pl’ imdb/imdbtask_3.pl 100%[===================>] 24.51K --.-KB/s in 0.06s 2019-06-02 04:26:06 (445 KB/s) - ‘imdb/imdbtask_3.pl’ saved [25095/25095] --2019-06-02 04:26:06-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_4.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 25093 (25K) [text/plain] Saving to: ‘imdb/imdbtask_4.pl’ imdb/imdbtask_4.pl 100%[===================>] 24.50K --.-KB/s in 0.06s 2019-06-02 04:26:07 (438 KB/s) - ‘imdb/imdbtask_4.pl’ saved [25093/25093] Helperscripts Found OK Deleting all Cached Files older then 5 Days Splitting XML in 11MB Files no element found at line 7, column 0, byte 215 at /usr/lib/x86_64-linux-gnu/perl5/5.22/XML/Parser.pm line 187. Creating Index for Splitted Files Merging Splitted XML Files together no element found at line 7, column 0, byte 215 at /usr/lib/x86_64-linux-gnu/perl5/5.22/XML/Parser.pm line 187. at /usr/bin/xml_merge line 65. at /usr/bin/xml_merge line 65. Deleting Workfiles Map Ratings in Desctription --2019-06-02 04:26:08-- https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/ratingmapper/ratingmapper.pl Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 6006 (5.9K) [text/plain] Saving to: ‘mapper/ratingmapper.pl’ mapper/ratingmapper 100%[===================>] 5.87K --.-KB/s in 0.001s 2019-06-02 04:26:08 (5.14 MB/s) - ‘mapper/ratingmapper.pl’ saved [6006/6006] Reading XML file no element found at line 7, column 0, byte 215 at /usr/lib/x86_64-linux-gnu/perl5/5.22/XML/Parser.pm line 187. real 0m20.949s user 0m1.656s sys 0m1.055s
@antaril
Nich ganz das selbe..Was sagt denn mono --version 4.2 ?
Da ist was mit dem mono faul..
der bug :
"Method 'Array.Empty' not found"
ist in 16.04 bekannt.Teste mal bitte mono 5.x
Codesudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF sudo apt install apt-transport-https ca-certificates echo "deb https://download.mono-project.com/repo/ubuntu stable-xenial main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list sudo apt update
Danach nochmal
apt install mono-complete
Wie gesagt, ich hab das Grabben nur raus
So:
Brainfuck
Alles anzeigen#!/usr/bin/perl -w use utf8; use strict; use warnings; use Term::ANSIColor; binmode (STDERR,"encoding(utf8)"); print STDERR "Start merging XMLś\n"; system('/bin/bash merge.sh'); wait; print STDERR "Replace Channel IDś into Rytec ones\n"; qx{wget -O mapper/channelmapper_rytec.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/channelmapper/channelmapper_rytec.pl}; qx{chmod 0777 mapper/channelmapper_rytec.pl}; qx{mapper/channelmapper_rytec.pl < xml/guide.xml > xml/guide-rytec.xml}; print STDERR "Map Genre into EIT\n"; qx{wget -O mapper/genremapper.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/genremapper/genremapper.pl}; qx{chmod 0777 mapper/genremapper.pl}; qx{mapper/genremapper.pl < xml/guide-rytec.xml > xml/guide-mapped.xml}; print STDERR "Start IMDB-Mapper\n"; qx{wget -O imdb/age.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/age.php}; qx{wget -O imdb/country.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/country.php}; qx{wget -O imdb/imdb.class.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdb.class.php}; qx{wget -O imdb/run.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/run.pl}; qx{wget -O imdb/poster.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/poster.php}; qx{wget -O imdb/rating.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/rating.php}; qx{wget -O imdb/url.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/url.php}; qx{wget -O imdb/year.php https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/year.php}; qx{wget -O imdb/imdbtask_1.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_1.pl}; qx{wget -O imdb/imdbtask_2.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_2.pl}; qx{wget -O imdb/imdbtask_3.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_3.pl}; qx{wget -O imdb/imdbtask_4.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/new_imdbmapper/imdbtask_4.pl}; qx{chmod 0777 imdb/*}; qx{imdb/run.pl xml/guide-mapped.xml xml/guide-imdb.xml}; print STDERR "Map Ratings in Desctription\n"; qx{wget -O mapper/ratingmapper.pl https://raw.githubusercontent.com/DeBaschdi/EPGScripts/master/ratingmapper/ratingmapper.pl}; qx{chmod 0777 mapper/ratingmapper.pl}; qx{mapper/ratingmapper.pl xml/guide-imdb.xml > guide-finish.xml};
Klar, es lief ja nicht einmal durch, von selbst. Am Schluss kam immer das selbe ...
Mal eine Zwischenfrage:
Werden die fertigen EPG-Daten noch mal wiederkommen?
Weil das Kodi-Addon ist ja schon was Feines! -
@Musiktoto
Ist geplant /gewünscht/erhofft , ja. -
bisch dä beschtä DeBaschdi, grad läufts.... Danke für deine Mühe, deinen Schweiß und deine Tränen ;=)
Freu mich grad über dein allinone script...
sind die server von Magenta grad irgendwie down oder so? Hab hier ne menge time outs...
Scheint zu funktionieren, ist aber noch nicht fertig mit grabben.
105min später - alles fehlerfrei durch gelaufen!magst du bitte nochmal starten und die zeit veröffentlichen ?
Sollte jetzt 40%schneller sein -
Die letzte Fassung, 0.0.3, lief OOTB ohne was zu ändern. Danke
puh,
das wird ein ganz schönes durcheinander hier.
deine Magenta Version soie auch das projekt von easy4me klingen gut. aber Problem hierbei ist dass nicht alle Sender verfügbar sind wenn ich mir die Liste der Quellen so ansehe.
Da fehlen einige Sky Sender, Eurosport xtra usw. was bedeutet dass ich entweder beides benutzten müsste oder gleich bei der alten Version mit webgrabplus bleiben kann. -
@este das skript von @easy4me ist die Zukunft für selbstgrab Linux user.
Muss ich einfach zugeben....
Meine Variante entstand bei einem glas Rotwein inspiriert durch @lutzlustig um die Zeit bis zum fertigen XML EPG Download überbrücken zu können.Wenn du das geil findest, pass ich gerne die channels an, ist ja auf wg+ basierend.
magst du bitte nochmal starten und die zeit veröffentlichen ?Sollte jetzt 40%schneller sein
73min diesmal. Vorher irgendwas löschen sollte ich aber nicht, oder?
dann hab ich ja fast gut geschätzt
Ne , du musst nichts löschen...
Außer du modifizierst die 4 configs.xml (weniger channels) wie @utiltiy. -
@DeBaschdi
danke, ich passe das script selber an. sollte ja kein Problem sein zusätzlich ein, zwei andere inis einzubinden.
ich sehe das auch so dass sein script da die Zukunft ist, aber es fehlen halt noch ein paar Sender, die zugegeben nicht alle brauchen.
Aber für sky und hd-plus benutzer sind die fehlenden Sender wie Sport Feeds, buli Feeds, und Eurosport xtra interessant.Für Leute wie mich, die das ganze über nacht laufen lassen und nur ca. 70 Sender brauchen spielt die Geschwindigkeit eine untergeordnete Rolle.
Der merge in deinem Script ist auch sehr interessantdazu hätte ich eh noch eine Frage: von wo hast du das Eursport xtra epg. tv.de liefert bei mir falsche Daten. zumindest irgendwie verschoben.
echt ? Meine ini von tv.de (in meinem git) läuft eigtl anstandsfrei... hmm.
Sein skript erlaubt ja die einbindung externer xml epgquellen..
Wieso mach ich eigtl für ihn werbung?
Bin echt sehr enttäuscht.
Aber ja,dass ist ein anderes Thema.
Ich geb zu, ich bin auch nur ein Mensch... und ja @utiltiy hat irgentwo recht, bin angefresen /verärgert und naja..
Eigtl sollte ich darüber stehen...Ich meins ja auch nur gut..
Iss halt alles wie's is. Meist undankbar.
Prost ihr nerds, jetzt erstmal mit der fam. Grillen
(Unkraut ist weg) hauptsache -
Keine Sorge, ich für meinen Teil hab Verständnis und bin in keinster Weiße nachtragend
Anstatt das jeder sein Ding für sich macht, solltet Ihr eure Power zusammen legen. Wäre ein guter Weg
ich habs versucht offensichtlich aber irgentwas falsch gemacht.
Egal. Thema ende. -
Also lief alles anstandlos durch jetzt!! Danke für deine Arbeit!! Allerdings hätte ich noch gerne Österreich und Schweiz, geht das irgendwie?
kann man dein Allinone DIng auf Libreelec lauffähig machen? Da müßte man wohl alle Pakete mit rein compilieren?
