Use our website as usual with the usual advertising and tracking. For details, visit Privacy Policy. Or sign up for a paid subscription that does away with advertising and tracking.
On the page Privacy Policy you can revoke your consent at any time.
Subscribe to a paid subscription
Use our subscription almost ad-free and without tracking at a low price, monthly cancellable. You can find more subscription offers on our info page.
For use with advertising: We and our partners collect and process personal data (such as IP addresses, cookies or device identifiers) in order to improve and finance our website. Processing may also take place outside the EU/EEA, where there may not be a comparable level of data protection, e.g. in the USA. You can find more information about where the processing takes place here. The processing is carried out for the following purposes:
Store and/or retrieve information on a device
For the processing purposes shown to you, cookies, device identifiers or other information may be stored or accessed on your device. be stored or accessed. Ad measurement, content measurement, audience insights and product development
The performance of ads and content can be measured. Insights about the target groups that have seen the ads and content can be derived. Insights about the audiences who viewed the ads and content can be derived. Data can be used to to improve user experience and develop systems and software. Personalised advertisements
Ads can be personalised based on a profile. Data can be added to better personalise ads. Personalised contents
Content can be personalised based on a profile. Data can be added to better personalise content.
On the page Privacy Policy you will find a detailed overview of which partners process data for which purposes, in particular which partners create user profiles based on the data collected. We need your consent to process your data.
Hallo Leute, Habe lediglich die Möglichkeit über den TVFIRE Stick das ganze wieder zum laufen zu bringen ... bin aber schon am verzweifeln Habt ihr eine Lösung ??? Graaazie
@LuckyLuciano123 bin in der gleichen Situation. Hier mein Workaround:
ES File Explorer im Amazon AppStore runterladen und ausführen. Unter Netzwerk den "Remote-Manager" einschalten. und die IP-Adresse und den Port in ein FTP-Programm deiner Wahl eintippen (Ich empfehle FileZilla) und zum Pfad /Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.rtlnow/ navigieren. Hier die alte default.py mit der Neuen von @Firekodi ersetzen.
Hallo, ich habe Android 4.4.4 und da läuft bei mir nur mygica (Kodi fork). Hier hat bei mir das RTL now addon 0.4.12 bis letzte Woche funktioniert. Jetzt auch nicht mehr. Leider funktionieren alle eure Änderungen unter dieser Version nicht. Und RTL now 0.6.5 läuft wie gesagt bei mir nicht, da immer die Meldung "Die Abhängigkeit auf inputstream.adaptive in der Version 1.0.8 konnte nicht aufgelöst werden" kommt. Aber Version 0.4.12 lief ja. Vielleicht ist es auch möglich, die default.py dieser Version zu fixen. Wäre sehr cool, danke
Hallo, das selbe hatte ich auch, geh mal in die Benutzer Addons und auf Inputstream Einstellungen, diese dann aktivieren. Nun sollte das Update mit dem aktuellen Rtlnow funktioniert. Lg
hat jemand eine Idee, wie ich das Problem mit dem inputstream adaptive 1.0.8 in mygica 17.1 lösen kann, man kann es hier nicht aktivieren, wie ihr es beschrieben habt (Android 4.4. Kitkat - das aktuelle kodi funktioniert hier halt nicht). Ohne das kann ich RTL now einfach nicht fixen. Vielen Dank
Dann hat die Shield Android Oreo (8.0) mit API L 26, Oreo (8.1) hätte dann schon API L 27, so geht die Entwicklung halt weiter,
im laufe von 2019 wird es mehr Android Devices auf der Welt geben als diese Einwohner hat.
Eigentlich eine traurige Entwicklung, denn mehr als 60% dieser Devices liegen als Elektroschrott in den Schubladen, was könnte man damit alles gutes anstellen, schweift aber jetzt zuweit vom Thema ab.
super vielen Dank für die ausführliche Antwort, jetzt weiß ich Bescheid. Ich lade die alte Version von RTL now mal hoch. Ich selber beherrsche das Patchen in dieser Form leider nicht... Vielen Dank Ich bin mit meinem Smartphone einfach zufrieden und leider gibt es keine höhere Android Version
