steuerung über ip
  • krieg es nicht zum laufen , irgenwo ist der fehler
    was muss bei server eingetragen werden ?
    4 Internet access
    Externer Inhalt wiki.xbmc.org
    Use an HTTP proxy server to access the internet
    If your internet connection uses a proxy, configure it here.
    - Server
    Proxy server
    - Port
    Defines the port of the proxy server
    - Username
    Defines the username used for the proxy server
    - Password
    Defines the password used for the proxy server
    Internet connection bandwidth limitation
    If you have limited bandwidth available, select a suitable value here and XBMC will try to keep to these limits. ?</big>
