Shield Experience update 7.1
  • Anbei das Finale Changelog für 7.1
    WHAT'S NEW
    • GeForce NOW on SHIELD (Requires update to latest NVIDIA Games app)
      • Adds in-game microphone support using SHIELD Controller via internal microphone or connecting a headset into
        the 3.5mm port
      • Adds keyboard and mouse support
      • Supports new NVIDIA SHIELD TV app for faster login and virtual mouse controls
    • Returns NVIDIA Share for taking screenshots, recording gaming moments, and streaming to Twitch. Go to Settings > System to enable.
    • Adds new shortcut to instantly sleep your SHIELD (press Home + Back).
    • Adds “Restart” to quick settings
    • App updates:
      • Netflix app adds new sidebar for easier navigation
      • YouTube app adds voice playback controls and a personalized home screen channel
      • [US] Prime Video app adds X-Ray support
      • [France] Google Assistant now available
    ADDITIONAL ENHANCEMENTS
    System Improvements
    • Adds ability to control TV volume from Chromecast apps when volume is set to CEC Volume Control (up and down
      7 levels)
    • Adds 120 Hz display modes for supported TVs and monitors
    • Adds support for non-QWERTY keyboards such as AZERTY. Go to Settings > Preferences > Keyboard > Physical
      keyboards to manage.
    • Adds new keyboard shortcuts for Android TV navigation:
    • Home (CTRL+ESC)
    • Back (ESC)
    • Recent Apps (ALT+TAB)
    • Access GFN and GameStream on-screen controls (Hold ESC)
    Gaming Improvements
    [*]Improves accuracy of mouse movements in GeForce NOW and GameStream by disabling Android mouse acceleration
    Sideload Support
    [*]Adds keyboard and mouse support for PUBG Mobile.
    • Learn more here
    • To use alternate game mapping software, disable SHIELD Game mapper in Settings > Developer options > Input.
    [*]Adds microphone support for PUBG Mobile
    [*]Adds home screen app tiles for popular sideload apps like Chrome, Minecraft, Speedtest, and PUBG Mobile.
    New Settings
    [*]Adds option to block Bluetooth pairing requests (Settings > Security & restrictions)
    [*]Adds ability to see last wakeup source (Settings > About > Status > Up time)
    FIXES
    System
    [*]Resolves somes instances of SHIELD Pro becoming sluggish after a SHIELD software upgrade
    [*]Resolves instances of SHIELD system fan always running at maximum speed
    [*]Resolves issue where the Display mode setting was not persisting
    [*]Resolves instances where Talkback would become enabled after extended sleep
    Apps
    [*]Resolves low available bandwidth issue for GeForce NOW when connecting over Wi-Fi. Results in up to 5X more bandwidth for dramatically improved quality and performance.
    [*]Resolves rare instance in Netflix app where streams would fail to start
    [*]Resolves occasional instances in YouTube TV where video playback would stop after performing multiple seek commands
    [*]Resolves issue where a home screen channel was incorrectly being shown for SHIELD accessories app
    Compatibility
    [*]Resolves pairing issue with some Bluetooth connected speakers such as Samsung HW-J450 sound bar
    [*]Resolves pairing issue with Bluetooth keyboards (seen with all system languages except English)
    [*]Resolves HDMI-CEC wakeup issue on certain LG TVs
    [*]Resolves compatibility issues with USB webcams and USB microphones
    [*]Resolves issue with AVerMedia capture devices not working properly
    [*]Resolves issue where SHIELD would not wake from IR-based Logitech remotes
    [*]Resolves audio glitch on USB DAC when other devices are plugged into adjacent USB port
    External/Network Storage
    [*]Resolves instances of duplicate "Network Storage Unavailable" notifications
    [*]Resolves instances of external storage reporting as "0 bytes available"
    [*]Resolves issue where network storage could not be mounted if password was blank
    [*]Resolves issue where NAS connection would get lost after an Android framework restart. NAS now automatically
    remounts.
    [*]Improves NAS connection reliability
    SHIELD Remote/Controller
    [*]Improves responsiveness of volume slider on SHIELD Remote (2017)
    [*]Resolves instances of incorrect low battery notifications for SHIELD Remote (2017)
    [*]Resolves issue with SHIELD Remote (2015) on older firmware where charging would take a long time
    [*]SHIELD controller (2017) requires a firmware update every time system language is changed with “OK Google”
    enabled to update hotword language. Firmware update text now correctly informs users about the language change.
    [*]Latest accessory firmware versions:
    • SHIELD controller (2017): v1.25
    • SHIELD controller (2015): v1.96/99/3.71/0.32
    • SHIELD remote (2017): v1.35
    • SHIELD remote (rechargeable): v.1.30
  • Meine Shield hat mir das Update heute angezeigt, habs dann instalieren lassen. Bisher nichts negatives festgestellt.
  • Die Screenshoot können nun wieder über die Fernbedienung geschossen werden...tolle Sache...allerdings nicht über Kodi und Netflix...beim abspielen von Filmen und Serien.
    Man kann nun endlich eine Tastatur mit den deutschen Tastatur Treiber verwenden...ohne eine extra App dafür zu verwenden...schon jahrelang gewünscht...tolle Sache...nun klappt es auch mit den deutschen Sonderzeichen über Kodi.
  • Hat noch jemand das Problem, dass nur noch 50hz, 59,xx und 60 hz angeboten werden? Kann sowohl in den shield settings als auch in Kodi keine 24hz mehr aktivieren :(
    Aufbau ist Shield-> Pioneer VSX830 -> Epson Tw9200
    ich hab nen AVR dazwischen und mir werden alle Auflösungen angeboten ...
  • naja hatte dazu einen thread direkt bei google gelesen wo sich einige app devs für android aufgeregt habe das ihre app nicht mehr richtig funktioniert und dort wurde seitens google eindeutig klargestellt das dieser abruf ein sicherheitsrisiko darstellen würde und missbraucht werden könnte.
    aber @Onkel-W du hast recht, die hoffnung stirbt zuletzt :D
    wenn ich den thread nochmal finde hänge ich es hier an, dann kann sich jeder sein eigenes bild machen.
    edit: hier -> https://issuetracker.google.com/issues/37140047
  • dave90: Hat der AVR zwei HDMI out? Wenn ja, wenn da was dranhängt, zieh es mal ab. Bei mir lief danach alles wieder. Denke es liegt am 7.1 Update.
    Hey, sorry für die späte Rückmeldung. Ich konnte das Problem ebenfalls durch abziehen aller Geräte und einen darauf folgenden Neustart lösen ;) Danke für den Tipp!
