[Release] Laola1 Video Addon 2.0
  • nochmals probiert - leider ohne Unterpunkte wählen zu können:
    22:47:06 T:18446744072490891664 NOTICE: special://profile/ is mapped to: special://masterprofile/
    22:47:06 T:18446744072490891664 NOTICE: -----------------------------------------------------------------------
    22:47:06 T:18446744072490891664 NOTICE: Starting Kodi (16.0 Git:2016-02-20-a5f3a99). Platform: Android ARM 32-bit
    22:47:06 T:18446744072490891664 NOTICE: Using Release Kodi x32 build
    22:47:06 T:18446744072490891664 NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
    22:47:06 T:18446744072490891664 NOTICE: Running on Amazon AFTB with Android 5.1.0 API level 22, kernel: Linux ARM 32-bit version 3.4.0-perf-gbb9e58e
    22:47:06 T:18446744072490891664 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
    22:47:06 T:18446744072490891664 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
    22:47:06 T:18446744072490891664 NOTICE: Product: bueller, Device: bueller, Board: MSM8960 - Manufacturer: Amazon, Brand: Amazon, Model: AFTB, Hardware: qcom
    22:47:06 T:18446744072490891664 NOTICE: External storage path = /storage/emulated/0; status = ok
    22:47:06 T:18446744072490891664 NOTICE: ARM Features: Neon enabled
    22:47:06 T:18446744072490891664 NOTICE: special://xbmc/ is mapped to: /data/data/http://org.xbmc.kodi/cache/apk/assets
    22:47:06 T:18446744072490891664 NOTICE: special://xbmcbin/ is mapped to: /data/data/http://org.xbmc.kodi/cache/apk/assets
    22:47:06 T:18446744072490891664 NOTICE: special://masterprofile/ is mapped to: /storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/userdata
    22:47:06 T:18446744072490891664 NOTICE: special://home/ is mapped to: /storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi
    22:47:06 T:18446744072490891664 NOTICE: special://temp/ is mapped to: /storage/usbdisk/Android/data/http://org.xbmc.kodi/files/.kodi/temp
    22:47:06 T:18446744072490891664 NOTICE: The executable running is:
    22:47:06 T:18446744072490891664 NOTICE: Local hostname: localhost
    22:47:06 T:18446744072490891664 NOTICE: Log File is located: /storage/usbdisk/Android/data/http://org.xbmc.kodi/files/.kodi/temp/[definition=9,2]kodi.[definition='1','0']log[/definition][/definition]
    22:47:06 T:18446744072490891664 NOTICE: load settings...
    22:47:06 T:18446744072490891664 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
    22:47:06 T:18446744072490891664 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
    22:47:06 T:18446744072490891664 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
    22:47:06 T:18446744072490891664 DEBUG: AESinkAUDIOTRACK - 44100 supported
    22:47:06 T:18446744072490891664 DEBUG: AESinkAUDIOTRACK - 48000 supported
    22:47:06 T:18446744072490891664 DEBUG: AESinkAUDIOTRACK - 96000 supported
    22:47:06 T:18446744072490891664 NOTICE: Found 1 Lists of Devices
    22:47:06 T:18446744072490891664 NOTICE: Enumerated AUDIOTRACK devices:
    22:47:06 T:18446744072490891664 NOTICE: Device 1
    22:47:06 T:18446744072490891664 NOTICE: m_deviceName : AudioTrack
    22:47:06 T:18446744072490891664 NOTICE: m_displayName : android
    22:47:06 T:18446744072490891664 NOTICE: m_displayNameExtra: audiotrack
    22:47:06 T:18446744072490891664 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
    22:47:06 T:18446744072490891664 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
    22:47:06 T:18446744072490891664 NOTICE: m_sampleRates : 48000,44100,48000,96000
    22:47:06 T:18446744072490891664 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
    22:47:06 T:18446744072490891664 DEBUG: CSkinSettings: no <skinsettings> tag found
    22:47:06 T:18446744072490891664 NOTICE: No settings file to load (special://xbmc/system/[definition='2','1']advancedsettings[/definition].xml)
    22:47:06 T:18446744072490891664 NOTICE: No settings file to load (special://masterprofile/[definition='2','1']advancedsettings[/definition].xml)
    22:47:06 T:18446744072490891664 NOTICE: Default DVD Player: dvdplayer
    22:47:06 T:18446744072490891664 NOTICE: Default Video Player: dvdplayer
    22:47:06 T:18446744072490891664 NOTICE: Default Audio Player: paplayer
    22:47:06 T:18446744072490891664 NOTICE: Disabled debug logging due to GUI setting. Level 0.
    22:47:06 T:18446744072490891664 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
    22:47:06 T:18446744072490891664 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
    22:47:06 T:18446744072490891664 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
    22:47:06 T:18446744072490891664 NOTICE: Loaded playercorefactory configuration
    22:47:06 T:18446744072490891664 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
    22:47:06 T:18446744072490891664 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
    22:47:06 T:18446744072490891664 NOTICE: Running database version Addons20
    22:47:06 T:18446744072490891664 NOTICE: ADDONS: Using repository repository.xbmc.org
    22:47:06 T:18446744072490891664 NOTICE: ADDONS: Using repository repository.xhaggi
    22:47:06 T:18446744072490891664 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
    22:47:06 T:18446744072490891664 NOTICE: CEGLNativeTypeAndroid: Switching to resolution:
    22:47:06 T:18446744072490891664 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
    22:47:06 T:18446744072490891664 NOTICE: Previous line repeats 1 times.
    22:47:06 T:18446744072490891664 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
    22:47:06 T:18446744072490891664 NOTICE: Found (1920x1080@60.000000) at 16, setting to RES_DESKTOP at 16
    22:47:06 T:18446744072490891664 NOTICE: Checking resolution 16
    22:47:06 T:18446744072490891664 NOTICE: CEGLNativeTypeAndroid: Switching to resolution: 1920x1080 @ 60.00 - Full Screen
    22:47:06 T:18446744072490891664 NOTICE: GL_VENDOR = Qualcomm
    22:47:06 T:18446744072490891664 NOTICE: GL_RENDERER = Adreno (TM) 320
    22:47:06 T:18446744072490891664 NOTICE: GL_VERSION = OpenGL ES 3.0 V@84.0 AU@05.00.02.006.020 (CL@)
    22:47:06 T:18446744072490891664 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
    22:47:06 T:18446744072490891664 NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_sync GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_EXT_texture_filter_anisotropic GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_disjoint_timer_query
    22:47:06 T:18446744072490891664 ERROR: Unable to load libcec.so, reason: (null)
    22:47:06 T:18446744072490891664 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
    22:47:06 T:18446744072490891664 NOTICE: Running database version ViewModes6
    22:47:06 T:18446744072490891664 NOTICE: Running database version Textures13
    22:47:06 T:18446744072490891664 NOTICE: Running database version MyMusic56
    22:47:06 T:18446744072490891664 NOTICE: Running database version MyVideos99
    22:47:06 T:18446744072490891664 NOTICE: Running database version TV29
    22:47:06 T:18446744072490891664 NOTICE: Running database version Epg11
    22:47:07 T:18446744072490891664 ERROR: failed to load requested skin 'skin.titan'
    22:47:07 T:18446744072490891664 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
    22:47:07 T:18446744072490891664 NOTICE: ActiveAE DSP - starting
    22:47:07 T:18446744072490891664 NOTICE: initialize done
    22:47:07 T:18446744072490891664 NOTICE: Running the application...
    22:47:08 T:18446744072490891664 NOTICE: starting zeroconf publishing
    22:47:08 T:18446744072490891664 NOTICE: starting upnp client
    22:47:08 T:18446744072490891664 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
    22:47:08 T:18446744072490891664 NOTICE: GL_VENDOR = Qualcomm
    22:47:08 T:18446744072490891664 NOTICE: GL_RENDERER = Adreno (TM) 320
    22:47:08 T:18446744072490891664 NOTICE: GL_VERSION = OpenGL ES 3.0 V@84.0 AU@05.00.02.006.020 (CL@)
    22:47:08 T:18446744072490891664 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
    22:47:08 T:18446744072490891664 NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_sync GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_EXT_texture_filter_anisotropic GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_disjoint_timer_query
    22:47:08 T:18446744072504253520 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
    22:47:08 T:18446744072504253520 NOTICE: UDP: Listening on port 9777
    22:47:08 T:18446744072499244456 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
    22:47:11 T:18446744072499234664 NOTICE: Skin Helper Service --> skin helper service version 1.0.56 started
    22:47:11 T:18446744072499234664 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
    22:47:12 T:18446744072499213872 NOTICE: script.grab.fanart: Grab Fanart Service Started
    22:47:14 T:18446744072499229192 NOTICE: Kodi Hue service started, version: 0.8b2
    22:48:06 T:18446744072490891664 NOTICE: CEGLNativeTypeAndroid: Switching to resolution: 1920x1080 @ 60.00 - Full Screen
    22:48:06 T:18446744072490891664 NOTICE: GL_VENDOR = Qualcomm
    22:48:06 T:18446744072490891664 NOTICE: GL_RENDERER = Adreno (TM) 320
    22:48:06 T:18446744072490891664 NOTICE: GL_VERSION = OpenGL ES 3.0 V@84.0 AU@05.00.02.006.020 (CL@)
    22:48:06 T:18446744072490891664 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
    22:48:06 T:18446744072490891664 NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_sync GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_EXT_texture_filter_anisotropic GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_disjoint_timer_query
    22:49:33 T:18446744072490891664 NOTICE: Samba is idle. Closing the remaining connections
    22:49:57 T:18446744072501263864 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    Error Type: <type 'exceptions.IndexError'>
    Error Contents: list assignment index out of range
    File "/storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/a…free/default.py", line 41, in <module>
    handler.handle()
    File "/storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/a…lib/handlers.py", line 123, in handle
    block = self.cache_load()
    File "/storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/a…lib/handlers.py", line 90, in cache_load
    return self.cacheManager.load(self.idParts)
    File "/storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/a…/lib/caching.py", line 36, in load
    del idPartsNew[-1]
    IndexError: list assignment index out of range
    22:49:57 T:18446744072490891664 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.laola1free/?id=0&type=live-block&url=http%3a%2f%2fwww.laola1.tv%2fde-de%2flive-schedule
    22:49:57 T:18446744072490891664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.laola1free/?id=0&type=live-block&url=http%3a%2f%2fwww.laola1.tv%2fde-de%2flive-schedule) failed
    22:50:08 T:18446744072529526432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    handler.handle()
    File "/storage/usbdisk/Android/data/http://org.xbmc.kodi/files//.kodi/a…lib/handlers.py", line 110, in handle
    channel = self.cache_load()
    del idPartsNew[-1]
    22:50:09 T:18446744072490891664 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.laola1free/?id=2&type=channel
    22:50:09 T:18446744072490891664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.laola1free/?id=2&type=channel) failed
    22:50:11 T:18446744072535655392 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    handler.handle()
    del idPartsNew[-1]
    22:50:11 T:18446744072490891664 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.laola1free/?id=1&type=channel&url=http%3a%2f%2fwww.laola1.tv%2fde-de%2fchannel%2fhome-deutschland
    22:50:11 T:18446744072490891664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.laola1free/?id=1&type=channel&url=http%3a%2f%2fwww.laola1.tv%2fde-de%2fchannel%2fhome-deutschland) failed
  • Es scheint als wäre der cache nicht korrekt aufgebaut. Hast du das Plugin unter deinen Favoriten?
    Kannst du versuchen über Video->Addons->laola1.tv free drauf zu gehen, ob es so auch passiert. Ich habe das Gefühl der CacheManager vom Addon und der Cache von Kodi kommen sich in die Quere.
    Nachdem du ja auch an den Log gekommen bist.
    Könntest du bitte nachsehen, ob die Datei
    /storage/usbdisk/Android/data/http://org.xbmc.kodi/files/.kodi/us…ache/cache.json existiert?
  • Addon funktionierte auch über den Weg Video>Addons nicht. Im Verzeichnis existierte die Datei auch nicht.
    Ich habe jetzt Kodi neuinstalliert. Jetzt funktioniert auch das Addon.
    Dank für die Hilfe!
  • Hallo zusammen
    hier mal mein [definition='1','0']log[/definition]
    bei mir gehts auch nicht
    20:36:41 T:139838990513920 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    Error Contents: list index out of range
    File "/home/michael/.kodi/addons/plugin.video.laola1free/default.py", line 45, in <module>
    handler.handle()
    File "/home/michael/.kodi/addons/plugin.video.laola1free/resources/lib/handlers.py", line 113, in handle
    channelsOrBlocks = self.fetch_home()
    File "/home/michael/.kodi/addons/plugin.video.laola1free/resources/lib/handlers.py", line 105, in fetch_home
    channels = extractor.get_channels()
    File "/home/michael/.kodi/addons/plugin.video.laola1free/resources/lib/extraction.py", line 227, in get_channels
    return [self.extract_live_block(soup)] + self.extract_channels(soup.select('.quick-browse .level1 > li'))
    File "/home/michael/.kodi/addons/plugin.video.laola1free/resources/lib/extraction.py", line 79, in extract_live_block
    link = parent.select('.meta a.live')[0]
    IndexError: list index out of range
    20:36:41 T:139839911430272 ERROR: GetDirectory - Error getting plugin://plugin.video.laola1free/
    20:36:41 T:139839911430272 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.laola1free/) failed
  • Servus,
    bitte immer folgendes machen bei Fehlern:
    [definition='1','3']Debug[/definition] [definition='1','0']log[/definition] aufdrehen (entweder kodi weit oder in den addon settings - seit 1.1.0)
    Die Aktion erneut probieren und den [definition='1','0']log[/definition] auf pastebin.com laden und hier verlinken.
    Ich kann nur von meinen Systemen auf andere schließen (win7, openelec, Android). Bei mir funktioniert alles wie es soll. Ohne alle Informationen zu haben tue ich mir schwer. Ich bemühe mich ein so stabiles addon wie möglich zu entwickeln, brauche da aber auf jeden Fall die Hilfe der Nutzer.
    Danke,
    Alex
  • Danke!
    In einer Hinsicht hat es schon mal weitergeholfen. Die [definition='1','3']Debug[/definition] option im Addon dürfte auch nicht auf allen systemen gleich funktionieren.
    Ich habe eine 1.1.1 released. Bitte installieren und das Prozedere erneut durchführen. Sorry, dass es nicht gleich der richtige Output war, sonst hätte ich vl das Problem bereits beheben können.
    Interessant ist aber trotzdem, warum es auf all meinen Systemen funktioniert und bei dir nicht.
    Hast du mal versucht Sprache bzw. Land umzustellen, ob es da auch auftritt?
  • Scheint ein Problem mit BeautifulSoup zu sein, bzw. dem lxml parser der hier anscheinend verwendet wird auf deiner Maschine.
    Bitte folgendes probieren:
    Bei der Datei <home>/.kodi/addons/plugin.video.laola1free/resources/lib/extraction.py
    Zeile 17:
    Python
    return BeautifulSoup(source)
    ersetzen mit
    Python
    return BeautifulSoup(source, 'html.parser')
    und probieren, ob dies den Fehler behebt. Unter Umständen funktioniert das starten eines Streams trotzdem nicht, aber damit wäre schonmal die Ursache gefunden.
