    ich hoffe das es die richtige Stelle ist
    19:28:17.145 T:1717850880DEBUG: Thread LanguageInvoker start, auto delete: false
    19:28:17.145 T:1717850880INFO: initializing python engine.
    19:28:17.145 T:1717850880DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py): start processing
    19:28:17.543 T:1462760192DEBUG: CMMALVideo::Decode - ret(0) pics(0) inputs(0) slept(500) queued(0.22) (1118.66:1118.44) full(0) flags(0) preroll(0) eos(1 55892/-1)
    19:28:17.564 T:1926072832DEBUG: ------ Window Init (DialogBusy.xml) ------
    19:28:17.617 T:1717850880DEBUG: -->Python Interpreter Initialized<--
    19:28:17.617 T:1717850880DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py"
    19:28:17.618 T:1717850880DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.zattooHiQ:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
    19:28:17.618 T:1717850880DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py): entering source directory /home/osmc/.kodi/addons/plugin.video.zattooHiQ
    19:28:17.618 T:1717850880DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py): instantiating addon using automatically obtained id of "plugin.video.zattooHiQ" dependent on version 2.14.0 of the xbmc.python api
    19:28:17.751 T:1895908096DEBUG: ActiveAE::SyncStream pll:0.00000 (act:1.00000 lim:0.00000) rr:0.99978 threshold:0.020 error:-4.495419
    19:28:17.823 T:1462760192DEBUG: CMMALVideo::SetDropState - bDrop(1)
    19:28:17.828 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 72982 (+45)
    19:28:17.864 T:1462760192DEBUG: OutputPicture - dropped in output
    19:28:17.948 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73028 (+6)
    19:28:17.963 T:1462760192DEBUG: OutputPicture - dropped in output
    19:28:18.002 T:1462760192DEBUG: Previous line repeats 2 times.
    19:28:18.003 T:1462760192DEBUG: CMMALVideo::SetDropState - bDrop(0)
    19:28:18.006 T:1462760192DEBUG: OutputPicture - dropped in output
    19:28:18.071 T:1926072832DEBUG: Previous line repeats 1 times.
    19:28:18.071 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73035 (+6)
    19:28:18.192 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73042 (+6)
    19:28:18.313 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73049 (+7)
    19:28:18.433 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73057 (+6)
    19:28:18.557 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73064 (+6)
    19:28:18.678 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73071 (+7)
    19:28:18.751 T:1895908096DEBUG: ActiveAE::SyncStream pll:0.00000 (act:1.00000 lim:0.00000) rr:0.99971 threshold:0.020 error:-4.644148
    19:28:18.798 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73079 (+6)
    19:28:18.921 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73086 (+6)
    19:28:19.045 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73093 (+7)
    19:28:19.170 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73101 (+6)
    19:28:19.291 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73108 (+6)
    19:28:19.415 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73115 (+7)
    19:28:19.535 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73123 (+6)
    19:28:19.613 T:1717850880ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    Error Type: <type 'exceptions.KeyError'>
    Error Contents: ('session',)
    File "/home/osmc/.kodi/addons/plugin.video.zattooHiQ/plugin.py", line 93, in <module>
    premiumUser=accountData['session']['user']['subscriptions']!=[]
    KeyError: ('session',)
    19:28:19.637 T:1926072832DEBUG: ------ Window Init (DialogNotification.xml) ------
    19:28:19.648 T:1462760192DEBUG: CMMALVideo::SetDropState - bDrop(1)
    19:28:19.659 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73130 (+6)
    19:28:19.751 T:1895908096DEBUG: ActiveAE::SyncStream pll:0.00000 (act:1.00000 lim:0.00000) rr:0.99971 threshold:0.020 error:-4.643306
    19:28:19.781 T:1926072832DEBUG: CMMALRenderer::RenderUpdate - vsync 73137 (+7)
    19:28:19.810 T:1717850880INFO: Python script stopped
  • Ich musste das alte Addon deinstallieren, damit die v1.6.5 jetzt nach Neuinstallation läuft.
    C:\Users\xxxxxx\AppData\Roaming\Kodi\addons\plugin.video.zattooHiQ (nach deinstallation weg)
    C:\Users\xxxxxx\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.zattooHiQ (manuell gelöscht)
    Vielen Dank @rolapp für deinen zeitnahen Service :thumbup:
    Shield Pro 2019 (ATV9 Stock) | Mecool M8S Pro 2018 (ATV9 Custom)
    Shield 2017 (ATV9 Stock) | Beelink GT1 2016 (ATV7 Custom)
    Kodi 19.3 (Skin by pkscout | Screensaver by enen92)
  • cache Dateien über die Einstellungen löschen und Kodi neustarten. Das sollte auch funktionieren. Ich lasse die cache Dateien bei Update nicht löschen, damit das Login erhalten bleibt.
    Habs mir mal weggespeichert :rolleyes:
    So die Shield ist auch versorgt (auch mit Deinstallation vorher). Später noch die China-Box, aber erstmal F1 & Fußball gucken.
  • @rolapp Danke, die v1.6.5 läuft, auch in Verbindung mit dem Zattoo-PVR! Vielen Dank für die Arbeit.
    Ein Tipp an alle, bei denen es nicht funktioniert: Alle alten Video-Addons (Extended, Box, HiQ2) von Zattoo komplett löschen und nach Neustart die Zattoo-HiQ frisch installieren.
    Gruss, oliaros
  • @ Rolapp: Vielen Dank für das Update. Es funktioniert alles tipptop.
    es hat bei mir gereicht im Verzeichnis \Userdata\addon_data\plugin.video.zattooHiQ mit Ausnahme von settings.xml alle Dateien zu löschen und danach Kodi neu zu starten
    nach einiger Zeit mal wieder dieses Addon getestet, Login funktioniert.
    Zwei Sachen die mir aufgefallen sind:
    1. Wenn ich Replay benutze (Swiss IP), springt er nach dem Ende der Sendung ins Live Programm.
    Wäre es nicht sinnvoller, wenn zur nachfolgenden Sendung (ähnlich wie im Browser/Zattoo App), gesprungen wird?
    2. Das durchklicken, also die Reaktion auf Tastendruck im EPG ist sehr zäh, liegt das womöglich daran, das jeweils
    EPG-Daten nachgeladen werden? Das PVR Addon reagiert dort sofort.
    Ansonsten: weiter so!
  • Ihr Glücklichen... Bei mir geht es seit dem Update von 1.6.4.1 auf 1.6.5 vorhin nicht mehr. 1.6.4.1 war schon hakelig und hatte wie es schien Probleme mit der "urllib2.py". Aber nach einigen Reboots hatte es dann funktioniert.
    Bei 1.6.5 setzt sich das nun fort.
    Ist ein frisch aufgesetztes Odroid C2 System. Ich nehme mal an, dass die "urllib2.py" für´s "name resolving" zusändig ist ?
    Code-Schnipsel:
    15:57:49.445 T:546593304800 ERROR: Traceback (most recent call last):
    File "/home/chewitt/LibreELEC.82-images/build.LibreELEC-Odroid_C2.aarch64-8.2.5/LibreELEC-settings-0768930/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 271, in load_url
    File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
    File "/usr/lib/python2.7/urllib2.py", line 429, in open
    File "/usr/lib/python2.7/urllib2.py", line 447, in _open
    File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
    File "/usr/lib/python2.7/urllib2.py", line 1228, in http_open
    File "/usr/lib/python2.7/urllib2.py", line 1198, in do_open
    URLError: <urlopen error [Errno -3] Temporary failure in name resolution>
    15:57:49.553 T:545922216160 ERROR: ## LibreELEC Addon ## oe::load_url(https://update.libreelec.tv/updates.php?i=…h64&v=8.2.5&l=0
    ) ## ERROR: (URLError(gaierror(-3, 'Temporary failure in name resolution'),))
    15:57:49.553 T:545922216160 ERROR: Traceback (most recent call last):
    File "/usr/lib/python2.7/urllib2.py", line 1241, in https_open
    15:57:49.558 T:545922216160 ERROR: ## LibreELEC Addon ## system::check_updates_v2 ## ERROR: (TypeError('expected string or buffer',))
    15:57:49.558 T:545922216160 ERROR: Traceback (most recent call last):
    File "/home/chewitt/LibreELEC.82-images/build.LibreELEC-Odroid_C2.aarch64-8.2.5/LibreELEC-settings-0768930/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/system.py", line 768, in check_updates_v2
    File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
    File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
    TypeError: expected string or buffer
    17:09:44.392 T:547796775136 ERROR: GetDirectory - Error getting
    17:09:45.031 T:545874284768 ERROR: Previous line repeats 6 times.
    17:09:45.031 T:545874284768 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    File "/storage/.kodi/addons/plugin.video.zattooHiQ/plugin.py", line 93, in <module>
    17:09:45.129 T:547813564416 ERROR: GetDirectory - Error getting plugin://plugin.video.zattooHiQ/
    17:09:45.130 T:547813564416 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.zattooHiQ/) failed
    17:09:54.419 T:546601693408 ERROR: GetDirectory - Error getting
    17:10:23.705 T:545460842720 ERROR: Previous line repeats 2 times.
    17:10:23.705 T:545460842720 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    17:10:58.760 T:547813564416 ERROR: Previous line repeats 1 times.
    17:10:58.760 T:547813564416 NOTICE: Samba is idle. Closing the remaining connections
    17:13:26.039 T:547813564416 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
    17:13:26.375 T:545874284768 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    17:13:26.470 T:547813564416 ERROR: GetDirectory - Error getting plugin://plugin.video.zattooHiQ/
    17:13:26.470 T:547813564416 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.zattooHiQ/) failed
  • @vel2000
    ..... Wenn ich Replay benutze (Swiss IP), springt er nach dem Ende der Sendung ins Live Programm.
    Wäre es nicht sinnvoller, wenn zur nachfolgenden Sendung (ähnlich wie im Browser/Zattoo App), gesprungen wird? ....
    Das ist wirklich eine tolle Idee.
    Wenn es Dir @rolapp möglich wäre dies umzusetzen wäre das klasse.
    Freue mich schon nächste Woche Dein aktualisiertes Addon auszuprobieren.
    X96 Air Smart TV Box 4GB RAM + 32GB ROM
    Kodi 18.9
    CoreELEC 9.2.5
    Amlogic S905X3 64-bit Quad-core
  • @Pumpino
    Der Ordner ist schon OK! Zip-File mit dem jüngsten Datum/Uhrzeit entpacken. Das Meiste steht in der 01_KODI.[definition='1','0']log[/definition].
    Nimm aber einen Editor der XML-Dateien vernünftig darstellen kann. Beim On-Board-Windows-Texteditor kommt ziemlicher Murks.
  • Problem found - lost credentials and mess database - osmc (last update) + raspberry pi 3
    starting almost a month ago this add-on started to behave strange (don't knw if is from the fact Ifound EPG is working better than in previous versions)
    the trouble is that at one point it loses credentials
    I have found a way to reproduce
    1. Start some show from EPG or search
    2. when the show is finished (not stopped manually) will wait for several seconds and then will start the live stream on the same channel
    3. let it like this over 15~30 minutes and try to stop it - it will not stop - using escape ( exit from remote ) you get back in KODI
    4. any attempt to start the plugin ( even after reboot ) will ask for credentials
    I think the former session blocks something (lock oraccess to database) and the new one is not able to start
    At each several this "hangs" the database will get messy and something will not wrk ( EPG or search or recordings ...)
    Sometime clearing database will not work
    workaround
    - uninstall reboot and then install
    - use indigo to clean kodi
  • Genügt das zur Fehlerfindung???
    script error report<--
    19:12:23.079 T:1962364928 ERROR: GetDirectory - Error getting plugin://plugin.video.zattooHiQ/
    19:12:23.081 T:1962364928 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.zattooHiQ/) failed
    19:12:26.673 T:1721492384 ERROR: GetDirectory - Error getting
    19:12:29.539 T:1962364928 NOTICE: Storing total System Uptime
    19:12:29.540 T:1962364928 NOTICE: Saving settings
    19:12:29.628 T:1962364928 NOTICE: Saving skin settings
    19:12:29.641 T:1962364928 NOTICE: stop all
    19:12:29.641 T:1962364928 NOTICE: stop player
    19:12:29.641 T:1962364928 NOTICE: ES: Stopping event server
    19:12:30.007 T:1546646432 NOTICE: ES: UDP Event server stopped
    19:12:30.025 T:1962364928 NOTICE: stopping upnp
    19:12:30.178 T:1962364928 NOTICE: stopping zeroconf publishing
    19:12:30.183 T:1962364928 NOTICE: CWebServer[8080]: Stopped
    19:12:30.456 T:1962364928 NOTICE: stop dvd detect media
    19:12:31.136 T:1962364928 NOTICE: clean cached files!
