  • Achso nee, ich dachte du meintest das [definition='1','0']log[/definition], welches meson-ir auswirft. Moment, [definition=9,2]kodi.[definition='1','0']log[/definition][/definition] editiere ich hier rein...
    [definition=9,2]kodi.[definition='1','0']log[/definition][/definition]:
    19:10:31.878 T:4095299600 DEBUG: LIRC: Update - NEW at 184401:b 0 KEY_0 devinput (KEY_0)
    19:10:31.878 T:4095299600 DEBUG: HandleKey: 207 (0xcf, obc48) pressed, action is Number0
    19:10:34.077 T:3779093392 DEBUG: Thread JobWorker 3779093392 terminating (autodelete)
    19:10:34.388 T:4095299600 DEBUG: LIRC: Update - NEW at 186912:2 0 KEY_1 devinput (KEY_1)
    19:10:34.388 T:4095299600 DEBUG: HandleKey: 206 (0xce, obc49) pressed, action is Number1
    19:10:35.813 T:4095299600 DEBUG: LIRC: Update - NEW at 188336:3 0 KEY_2 devinput (KEY_2)
    19:10:35.813 T:4095299600 DEBUG: HandleKey: 205 (0xcd, obc50) pressed, action is JumpSMS2
    19:10:36.895 T:4095299600 DEBUG: LIRC: Update - NEW at 189418:4 0 KEY_3 devinput (KEY_3)
    19:10:36.896 T:4095299600 DEBUG: HandleKey: 204 (0xcc, obc51) pressed, action is JumpSMS3
    19:10:38.182 T:4095299600 DEBUG: LIRC: Update - NEW at 190705:5 0 KEY_4 devinput (KEY_4)
    19:10:38.182 T:4095299600 DEBUG: HandleKey: 203 (0xcb, obc52) pressed, action is JumpSMS4
    19:10:39.384 T:4095299600 DEBUG: LIRC: Update - NEW at 191908:6 0 KEY_5 devinput (KEY_5)
    19:10:39.384 T:4095299600 DEBUG: HandleKey: 202 (0xca, obc53) pressed, action is JumpSMS5
    19:10:40.639 T:4095299600 DEBUG: LIRC: Update - NEW at 193162:7 0 KEY_6 devinput (KEY_6)
    19:10:40.640 T:4095299600 DEBUG: HandleKey: 201 (0xc9, obc54) pressed, action is JumpSMS6
    19:10:41.792 T:4095299600 DEBUG: LIRC: Update - NEW at 194316:8 0 KEY_7 devinput (KEY_7)
    19:10:41.792 T:4095299600 DEBUG: HandleKey: 200 (0xc8, obc55) pressed, action is JumpSMS7
    19:10:42.798 T:4095299600 DEBUG: LIRC: Update - NEW at 195321:9 0 KEY_8 devinput (KEY_8)
    19:10:42.798 T:4095299600 DEBUG: HandleKey: 199 (0xc7, obc56) pressed, action is JumpSMS8
    19:10:43.968 T:4095299600 DEBUG: LIRC: Update - NEW at 196492:a 0 KEY_9 devinput (KEY_9)
    19:10:43.968 T:4095299600 DEBUG: HandleKey: record (0xc6) pressed, action is JumpSMS9
    19:10:46.234 T:4095299600 DEBUG: LIRC: Update - NEW at 198757:160 0 KEY_OK devinput (KEY_OK)
    19:10:46.234 T:4095299600 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
    19:10:46.234 T:4095299600 NOTICE: Disabled [definition=12,0]debug[/definition] [definition=12,9]logging[/definition] due to GUI setting. Level 0.
    19:10:46.234 T:4095299600 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
  • @koboltzz habe den Fehler gefunden, das war bei meiner Wetek genauso. es gehen die ziffen 0 und 1 die anderen geben JumpSMS aus. Welche Dateien hast du unter Userdata/keymaps?
    Hast du da eine Datei remote.xml ? wenn Ja folgendes ändern.
    wenn Nein die Datei dort einfügen. Das sollte es gewesen sein.
  • @rolapp
    Vielen Dank für deine Hilfe :)
    Allerdings soweit waren wir doch schon, dass das nicht klappt ;) :
    poste doch mal deine Keyboard.xml. meine angepasste siehe Anhang
    [...] Ich probiere jetzt deine.
    Edit: Deine [definition=10,0][definition='3','0']keymap[/definition][/definition].xml im userdata/keymaps Ordner ändert weder was im EPG noch ermöglicht die das Umschalten mit den Zifferntasten im Live-Tv
    Habe sie auch mal in remote.xml umbenannt, aber das ändert nichts. [definition=12,4][definition='1','3']Debug[/definition][/definition] [definition='1','0']log[/definition] liefert nach deinem Vorschlag immer noch JumpSMS.
  • @koboltzz schaue mal bitte genau hin. Die Sektion heißt remote und nicht keyboard
    <[definition=10,0][definition='3','0']keymap[/definition][/definition]>
    <global>
    <remote>
    <zero>Number0</zero>
    <one>Number1</one>
    <two>Number2</two>
    <three>Number3</three>
    <four>Number4</four>
    <five>Number5</five>
    <six>Number6</six>
    <seven>Number7</seven>
    <eight>Number8</eight>
    <nine>Number9</nine>
    </remote>
    </global>
    bei meiner Wetek ist die Fernbedienung vom Prinzip eine Tastatur , du hast aber ein IR Fernbedienung
  • Zitat von @koboltzz
    Seit libreelec 8.90.4 (also seit vorgestern) wurde von den libreelec Entwicklern dauerhaft auf "meson-ir" umgestellt, sodass man theoretisch nun jede beliebige Fernbedienung nach der Konfiguration benutzen kann. Die Konfiguration führt dazu, dass man jeder Taste eine Funktion zuordnen muss.
    wo hast du das gemacht? hast du unter userdata/keymaps noch irgendwelche Dateien? und mal bitte anhängen
    Deine Fernbedienung gibt nur Button Id's zurück bis auf 9 die gibt record aus.
    Welche Fernbedienung hast Du?
    Welche dateien hast du unter userdata/peripheral_data ? und mal bitte anhängen
    Welche dateien stehen in /storage/.kodi/config/rc_keymaps? und bitte mal anhängen
  • wo hast du das gemacht?
    Änderung ab Libreelec 9.0
    Nein
    Externer Inhalt antennmarket.ru
    Im Anhang :)
  • was steht in /storage/.config/rc_keymaps/ und die dateien mal anhängenwas steht in der Datei /storage/.config/rc_maps.cfg
    habe hier noch was gefunden remote
    Alles im Anhang :)
    minimxIII.txt liegt (als einzige Datei) ohne diese txt Dateiendung im rc_keymaps Ordner. rc_maps.txt liegt mit der Dateiendung cfg im .config Ordner.
    Also dieses meson-ir habe ich schon richtig konfiguriert, funktioniert ja alles (auch die Zahlentasten), bis auf EPG und das Kanalumschalten in ZattooHiQ.
  • Yeeeeah, du bist der Hammer!! :)
    Funktioniert! Vielen Dank für dein Engagement, obwohl ich der einzige mit dem Problem zu sein schein.
    Hast du dich bei Zeile 258 vertippt "ACTION_JUMP_SMS26" oder muss das so?
    Ich weiß, es ist viel verlangt, aber kannst du mir noch die Datei nennen, die für das Umschalten per Zahlentaste während LIve-TV verantwortlich ist?
    Wenn ich den Sender mit irgendeiner Zahl wechseln will, erscheint diese Zahl unten mittig in der Zeitangabe (als ob der Player vorspulen möchte, was natürlich bei Live-TV nicht geht=Kanalwechsel unmöglich).
  • Das freut mich riesig mit dem potentiellen Update :)
    Zur Zeit funktionieren leider die Ziffern 0 und 1 auch nicht. Wenn ich aus Spaß sechsmal hintereinander auf ARD= Programm 1 umschalten will steht für ein paar Sekunden in der Zeitangabe 11:11:11 (ausgehend von 00:00:01) und mehr passiert nicht. Das ändert sich auch nicht nach der Anwesenheit von deiner [definition=10,0][definition='3','0']keymap[/definition][/definition].xml oder remote.xml. Nur zur deiner Information :)
