  • Welche Plugin Version haste du den ?
    Libreelec V0519
    Netflix 0.13.5 von libdev + jojo + asciideisco
    Amazon VOD 0.5.4 von Sandman79, Varstahl
    habe mit beiden Plugins das gleiche Problem.
    Log nach Versuch Amazon Video zu starten:
    15:28:35.101 T:1423262576 NOTICE: [Amazon VOD] Version: 0.5.4
    15:28:35.101 T:1423262576 NOTICE: [Amazon VOD] Unicode filename support: False
    15:28:35.101 T:1423262576 NOTICE: [Amazon VOD] Locale: en-gb / Language: de
    15:28:46.315 T:1423262576 NOTICE: [Amazon VOD] getURL: https://atv-ps-eu.amazon.de/cdp/catalog/Browse?firmware=fmw%3A17-app%3A2.0.45.1210&deviceTypeID=A2M4YX06LWP8WI&deviceID=22fe85cd045f38e14a1af62141a8547aaa9e53ef36f91c79ecf92e69&format=json&version=2&formatVersion=3&marketplaceId=A1PA6795UKMFR9&IncludeAll=T&AID=1&OfferGroups=B0043YVHMY&ContentType=TVEpisode&RollUpToSeason=T&OrderBy=AvailabilityDate&MinAmazonRatingCount=40&HideNum=F&Preorder=F&Detailed=T&ContractID=UX%2A&NumberOfResults=40&StartIndex=0&tag=kodinerds04-21 [Anzeige]
    15:28:52.461 T:1411380080 NOTICE: [Amazon VOD] Starting Fanart Update
    15:28:52.499 T:1411380080 NOTICE: [Amazon VOD] Finished Fanart Update
    15:28:55.340 T:1423262576 NOTICE: [Amazon VOD] getURL: https://atv-ps-eu.amazon.de/cdp/catalog/Browse?firmware=fmw%3A17-app%3A2.0.45.1210&deviceTypeID=A2M4YX06LWP8WI&deviceID=22fe85cd045f38e14a1af62141a8547aaa9e53ef36f91c79ecf92e69&format=json&version=2&formatVersion=3&marketplaceId=A1PA6795UKMFR9&IncludeAll=T&AID=T&SeasonASIN=B07BBW7FJP%2CB07BBVWVYD%2CB07BBVL8B7%2CB07BBW4FCL&OfferGroups=B0043YVHMY&Detailed=T&ContentType=TVEpisode&IncludeBlackList=T&NumberOfResults=40&StartIndex=0&tag=kodinerds04-21 [Anzeige]
    15:28:59.193 T:1411380080 NOTICE: [Amazon VOD] Starting Fanart Update
    15:28:59.247 T:1411380080 NOTICE: [Amazon VOD] Finished Fanart Update
    15:29:02.012 T:1423262576 NOTICE: [Amazon VOD] Using Host: Cloudfront
    15:29:02.023 T:1423262576 NOTICE: [Amazon VOD] checkURL: https://d1l0nb3g075aoz.cloudfront.net/dm/2$Jy_weOI1QIYcXfBX0WZvWCCLwqM~/dfa7/b3ad/013d/470a-8035-2c7b6cdd80f2/bf75082e-20cb-4ac6-bff4-2498f372ecfa_corrected.mpd
    15:29:02.291 T:1423262576 NOTICE: [Amazon VOD] getURL: https://d1l0nb3g075aoz.cloudfront.net/dm/2$Jy_weOI1QIYcXfBX0WZvWCCLwqM/dfa7/b3ad/013d/470a-8035-2c7b6cdd80f2/bf75082e-20cb-4ac6-bff4-2498f372ecfa_corrected.mpd
    15:29:02.396 T:1423262576 NOTICE: [Amazon VOD] Using inputstream.adaptive Version:999.2.2.18
    15:29:02.397 T:1423262576 NOTICE: [Amazon VOD] Checking AudioTrack
    15:29:02.430 T:1940853936 NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
    15:29:02.436 T:1940853936 NOTICE: VideoPlayer::OpenFile: plugin://plugin.video.amazon-test/?asin=B07D41PK5T&mode=PlayVideo&adult=0&name=Was+bisher+geschah&trailer=0&selbitrate=0
    15:29:02.437 T:1384977264 NOTICE: Creating InputStream
    15:29:04.755 T:1384977264 ERROR: AddOnLog: InputStream Adaptive: Unable to find license;hdcpEnforcementResolutionPixels in JSON string
    15:29:04.755 T:1384977264 ERROR: AddOnLog: InputStream Adaptive: License update not successful (no keys)
    15:29:04.756 T:1384977264 ERROR: AddOnLog: InputStream Adaptive: Initialize failed (SingleSampleDecrypter)
    15:29:04.758 T:1384977264 ERROR: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.video.amazon-test/?asin=B07D41PK5T&mode=PlayVideo&adult=0&name=Was+bisher+geschah&trailer=0&selbitrate=0]
    15:29:04.759 T:1384977264 NOTICE: CVideoPlayer::OnExit()
    15:29:05.245 T:1940853936 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (2.79s)
    okay wenn ich die DVB Treiber zurück setze neustarte, funktioniert alles vom NAS problemlos, versuche ich dann was in Netflix/Amazon zu gucken o.g. Problem. Ich Nachhinein startet Kodi dann auch nichts mehr vom NAS. Muss dann wieder DVB Treiber zurück setzen und neustarten damit wenigstens Dateien vom NAS abegspielt werden können.
  • für DMR benutze ich https://github.com/emilsvennesson…helper/releases
    das läd alles nach sobald mann stram auf macht xD
    aber wie haste mit login gemacht bekomme 3 verschieden systemen nicht mal hin das proviel auswählen kann bei mir geht nur mit der version
    0.13.3 alles danach geht kein login mehr lol haste du sonderzeichen in password habe zb . und zallen werde daraus nicht schlau lol
    0.13.5 verion bekomme sofort erro selbst wenn erst alte drauf haue wo login geht dann update mache geht auch nicht selber fehler
    kannste ja mal testen mit script.module.inputstreamhelper meines ist zu lezt sogar mit 1080p gelaufen mit inputsrem habe eine S905w habe bissel overlockt xD ging es wird zwar 85crad normal hatte erst so 69crad
    meine [definition=12,0]debug[/definition] logs :
    Fehler dazu kein login password geändert ohne zallen und ohne . , / etc eifaches pw zum testen selbe geschichte das treibt mich noch in wasin soll coreelec [definition='1','0']log[/definition] auch anhängen wo der coder ( asciidisco) muss irgendwie reichen das mal fixen kann krasse ist mit 0.13.3 geht auf allen geräten das ja das krasse lol nur kann da nigs mehr abspielen
    https://paste.ubuntu.com/p/GMyHG7QzgM/ Windows [definition=12,0]debug[/definition]
    https://paste.ubuntu.com/p/npHH9JSfTC/ Android [definition=12,0]debug[/definition]
    dazu habe mir aktuellste http://mirrors.kodi.tv/nightlies/windows/win64/master/ kodi besorgt android / windows dazu habe mir noch mal 16h hingestelt und gitcode von coreelec zusammen gebaut mit intel atom cpu klar habe langsam fresse voll
    wenns sich an schaut sind fehler gleich in den logs selbe auch bei coreelec
    9 Mal editiert, zuletzt von Computerbastler18 (20. Mai 2018 um 18:32)
  • @Computerbastler18 wir können das gerne versuchen zu lösen, ich höre aber sofort auf (und mache auch nicht weiter) wenn hier weiter die Worte Fresse und Kacke fallen.
    - Installier CoreElec nochmal komplett neu
    - Installier kein Addon / kein skin -> Installier einfach nichts
    - leg in ~/.kodi/userdata/ eine Datei an die [definition='2','1']advancedsettings[/definition].xml heist mit folgendem Inhalt:
      <loglevel hide="false">1</loglevel>
    - Starte deine Kiste neu, und stelle das [definition=9,2]kodi.[definition='1','0']log[/definition][/definition] zur Verfügung.
    - Danach sehen wir weiter.
  • @w0nder87
    Wie im Amazon Thread schon geschrieben, laufen bei mir beide Addons (Amazon und Netflix) mit der vom inputstreamhelper gezogenen libwidevinecdm.
    Häng hier doch mal ein komplettes [definition=12,0]debug[/definition] [definition='1','0']log[/definition] an - gibt hier ja einige, die dir dann weiterhelfen können.
    Bei mir hats vorher auf meinem Pi, wie schon geschrieben, nach löschen der vorhandenen libwidevinecdm (um dann mit der vom inputstreamhelper gezogenen testen zu können) und Neuinstallation des Netflix Addons komischerweise erst nach manuellen installieren(aktualisieren) der cryptopy funktioniert!?
    Einmal editiert, zuletzt von debutanker (20. Mai 2018 um 23:34)
  • So ich bins nochmal,
    nochmal kurz zu meinem Problem besitze den PI3 mit der neuesten nightly 0519, Amazon und Netflix Plugin.
    Habe nach dem Starten des Amazon Plugins das widevinecpm über den Helper laden lassen. So weit so gut Amzon VOD funktioniert damit ohne Probleme sobald ich aber das Plugin auf Netflix wechsel und versuche einen Film oder Serie zu starten bekomme ich folgenden Fehler im [definition=12,3]Debug-Log[/definition] angezeigt:
    Log-File
    Jemand ne Ahnung woran das liegen könnte im Amazon Thread wurde versucht mir zu helfen einer konnte das Problem auch nachproduzieren aber durch nachinstallieren des raw.githubusercontent.com/kodi…module.cryptopy-1.2.6.zip beheben. Bei mir bleibt aber der oben genannte Fehler und es startet kein Videostream sondern er spirngt zurück in die Abspielliste.
  • Hatt jemand auch das Problem mit Login unter aktuellen Version habe Mal auf Windows und Android und CoreElec gesteste geht einfach nicht immer Log prüfen lustige ist mit älteren Version geht's aber kann halt nigs mehr abspielen
    Kann ein Fehler beim Speichern der settings sein.
    Bei Windows gebe mal im Explorer den Pfad ein: %appdata%\Roaming\Kodi\userdata\addon_data
    Und lösche das komplette plugin.video.netflix Verzeichnis.
    Danach sollte Kpodi das Verzeichnis wieder neu erstellen können. Anschließend musst du im Kodi nur noch die Settings für dieses Plugin neu setzen.
  • Hier das komplette File!
    Perfekt.
    Beim laden vom Manifest hast du folgenden Fehler:
    {"internalcode":205007,"messageid":1682519799160826,"errorcode":7,"errormsg":"Email or password is incorrect.","timestamp":1526854484}
    Am besten das Netflix-Plugin nochmal deinstallieren mit Einstellungen !! (wichtig) und dann LE nochmal neustarten und das Plugin wieder installieren.
    Dann nochmal sauber einloggen. Es kann auch helfen, wenn du dich vorher einmal am Browser einloggst.
    Was manchmal auch Probleme macht sind Sonderzeichen im Passwort.
    Bitte einmal so probieren.
    Habbe alle warianten versucht das war meine erste ide gewesen ...
    habe alles mögliche was mir eingefallen ist versucht
  • Mache es doch einfach mal so...wie peak3d es geschrieben hat und stelle ihm dann das [definition=9,3]Kodi.[definition='1','0']log[/definition][/definition] zur Verfügung.
  • Ähm ja [definition='1','0']log[/definition] sind oben bzw Seite vorher 2 logs 2 verschiedene Systeme Geste habe ich's auf 3
    1x Windows roh Zustand mit KODi neueste build Error
    1 x Android auf Handy mit 2 verschieden kodi einmal originale 18 dann aktuelle build beides selbe
    1x CoreElec wo mir noch Mühe gemacht habe gitcode zusammen zu komplitieren weil dachte das da an build klemt ... Offizielle relase Rohzustand dann aktuelle Browser einloggen war auch einer meiner ersten Vorschläge einzige was geht ist alte Version geht es auf allen Geräten
    Siehste mehr kann nicht machen auf normalen Wege gibs noch was aber nicht sein und Zweck TLS zu umgehen und zu sehen was genau übertragen wird per Man-in-the-Middle-Angriff (MITM-Angriff) auf Box damit Mann TLS aushebeln kann wäre mir einzige was einfällt ... Weiß soweit das Server Verbindung ablehnt warum auch immer
    Einmal editiert, zuletzt von Computerbastler18 (21. Mai 2018 um 11:42)
    ist es normal, dass Netflix nur über SW decodiert wird? Bei Amazon steht als Decoder MMAL, bei Netflix nur inputstream adaptive Decoder (SW). Dadurch hat mein RPi2 erhebliche Probleme mit höher aufgelösten Videos. Fehlt da eine Einstellung, oder ist das korrekt so? (Aktuelles Milhouse libreelec testbuild)
  • Wenn es nicht unter libreelec läuft dann z. B. Wireshark
    Haupsysteme: Server: Asrock N3160ITX, Ubuntu 22.04, TvH /// DVBSky 952 /// Wohnzimmer: Nvidia Shield Pro 2019
    Nebensysteme 1: Telestar Digibit R1 mit sat-axe14 /// Wohnzimmer: Asrock N3700, Libreelec 10 /// TvH @RPI4 Server /// Gästezimmer: Corelec 19 @ Tanix TX3
    Nebensysteme 2: Server: Asrock N3455M, OpenMediaVault6, TvH, Telestar Digibit R1 /// 4 Clients: Coreelec S905X
  • So wurde gefixt läuft aktuell wieder 0.13.6 wenn's auch eine ganze Weile gedauert hatt ...
    Einmal editiert, zuletzt von Computerbastler18 (23. Mai 2018 um 14:34)
