NFS Mount mit Libreelec
    ich versuche einen NFS Laufwerk von meinem NAS auf dem rasp2 unter libreelec zu mounten. Leider funktioniert es nicht.
    Von Hand mit dem Befehl mount 192.168.178.29:/nas-6tb /storage/nas-6tb funktioniert es. Wenn ich den Weg über das Mount-Scipt unter /storage/.config/... nehme, dann geht es nicht. Nach einem Neustart steht der Mount von NAS nicht zur Verfügung. Das Script sieht so aus:
    # This is a sample service script to mount NFS shares.
    # Please read carefully the comments in this file. For production usage
    # you can remove all comments (lines beginning with "#") from this file.
    [Unit]
    # The description should be used to explain what this servicefile is for
    Description=test nfs mount script
    # if we do network mounts like here we *require* 'network-online.service'
    # which checks if the network is online
    Requires=network-online.service
    # our scripts must start *after* 'network-online.service', on timeout and if
    # 'network-online.service' fails we can not mount and this scripts fails too
    After=network-online.service
    # usually we mount networks shares because we want they avaible *before* XBMC starts.
    # so XBMC has access to this mounts from beginning. Note: this slows down the boot!
    Before=kodi.service
    [Mount]
    # The share we want mount
    What=192.168.178.29:/nas-6tb
    # Where we want mount this share
    Where=/storage/nas-6tb
    # Any options you usually use with the "-o" parameter in the mount command
    Options=
    # filesystem type
    Type=nfs
    [Install]
    # The target is used by 'systemctl enable <name_of_this_file.mount>' to link
    # this service to a runlevel for starting on boot. usually 'multi-user.target'
    # is ok here.
    WantedBy=multi-user.target
    # Important:
    # this file must be renamed to <mountpoint>.mount where <mountpoint>, is the FULL path
    # where the share will be mounted but slashes "/" MUST BE REPLACED with dashes "-" with .mount
    # as extension.
    # This means, if we want mount to "/storage/movies2" (see above "Where=/storage/movies2")
    # then this file must be renamed to 'storage-movies2.mount' and can be enabled via ssh with the
    # command 'systemctl enable storage-movies2.mount'
    Kann mir jemand sagen wo das Problem liegt?
    Danke & Grüße,
    Der Busfahrer416
  • Dann hast es nicht nach Anleitung gemacht
    Da ist am Schluss
    systemctl enable storage-xyz.mount
    Das verstehe ich nicht. Hilf mir. Ich habe die Datei erstellt und in dem Verzeichnis /storage/.config/... abgespeichert. Dort liegen auch die Samples. Und dann habe ich das Kommando systemctl enable ausgeführt. Was ist daran falsch bzw. was habe ich vergessen?
  • Meine Vermutung: Dein mount hat ein "-" im Namen (die stehen aber für "/"). Benenne Deinen mount-Punkt einmal um (z.B. in nas6tb, also ohne "-"):
    Aber:
    Die Datei heißt: storage-nas6tb.mount
    Erkennst Du den Unterschied?
