Diskussionsthema zum How to: Soundgraph iMON VDF Display/IR mit XBMCbuntu 12.2
  • Hallo
    Habe das selbe Problemm, bekomme das DISPLAY einfach nicht ans Laufen, das einzigen was Angezeigt wird ist der STANDARD SATZ aus dem Treiber. siehe BILD
    Hat es eventuell von euch jemand mitllerweile hinbekommen. IR Funfktioniert. Habe das IMON VFD DISPLAY verbaut (siehe Bild)
    Danke
  • Hallo
    Danke für die Antwort
    Folgendes habe ich bereits gemacht.
    sudo apt-get install lcdproc
    sudo nano /etc/LCDd.conf
    Quellcode
    # The following drivers are supported:
    # bayrad, CFontz, CFontz633, CFontzPacket, curses, CwLnx, ea65,
    # EyeboxOne, g15, glcdlib, glk, hd44780, icp_a106, imon, imonlcd,
    # IOWarrior, irman, joy, lb216, lcdm001, lcterm, lirc, lis, MD8800,
    # mdm166a, ms6931, mtc_s16209x, MtxOrb, mx5000, NoritakeVFD, picolcd,
    # pyramid, sed1330, sed1520, serialPOS, serialVFD, shuttleVFD, sli,
    # stv5730, svga, t6963, text, tyan, ula200, xosd
    Driver=imon
    # Hello message: each entry represents a display line; default: builtin
    Hello="XBMC starting..."
    # GoodBye message: each entry represents a display line; default: builtin
    GoodBye="Thanks for using"
    GoodBye=" XBMC "
    # If yes, the the serverscreen will be rotated as a usual info screen. If no,
    # it will be a background screen, only visible when no other screens are
    # active. The special value 'blank' is similar to no, but only a blank screen
    # is displayed. [default: on; legal: on, off, blank]
    ServerScreen=off
    # Set master heartbeat setting. If set to 'open' a client may control the
    # heartbeat for its own screens (only). [default: open; legal: off, open, on]
    Heartbeat=off
    dann
    sudo nano ~/.xbmc/userdata/LCD.xml
    <lcd>
    <navigation>
    <line>$INFO[System.CurrentWindow]</line>
    <line>$INFO[System.CurrentControl]</line>
    </navigation>
    <music>
    <line>$INFO[Player.Time]/$INFO[Player.Duration]</line>
    <line>$INFO[MusicPlayer.Artist] - $INFO[MusicPlayer.Title] ----- </line>
    </music>
    <video>
    <line>$INFO[Player.Time(hh:mm)]/$INFO[Player.Duration(hh:mm)]</line>
    <line>$INFO[LCD.ProgressBar]</line>
    </video>
    <general>
    <line>$INFO[System.Time]</line>
    <line>$INFO[System.Date]</line>
    </general>
    <screensaver>
    </screensaver>
    <xbelaunch>
    <line>Playing</line>
    <line>$INFO[System.LaunchXBE]</line>
    </xbelaunch>
    </lcd
    dann
    sudo nano ~/.xbmc/userdata/[definition='2','1']advancedsettings[/definition].xml
    <lcd>
    <rows>2</rows>
    <columns>16</columns>
    <scrolldelay>3</scrolldelay>
    </lcd>
    dann
    sudo nano ~/.xbmc/userdata/guisettings.xml
    <haslcd>true</haslcd>
    Dieser WERT war in meiner guisettings.xml nicht vorhanden.
    Habe es dann unter VIDEOCREEN in der guisettings.xml eingetragen.
    dann
    /etc/init.d/LCDd restart
    Die Anleitung hatte ich hier aus dem Forum, habe lediglich im dateipfad xbmc gegen kodi getauscht da er sonst mir den Fehler anzeigt hat das es diese Datei nicht existiert.
    Mein System ist Kodibuntu Kodi Version 15.1
    ABER leider passiert nichts,
    Bin leider ein LINUX Neuling,
    Danke
  • probier mal:
    Quellcode
    Driver=imonlcd
    Ich meine das habe ich bei mir eingestellt. Ausserdem kommt da etwas tiefer noch was mit dem Protokoll.
    Dort kannst du auch mal die verschiedenen Einstellungen testen.
    Mein System:
    Server
    Wohnzimmer
    im Haus verteilt
    Cooler Master Elite 110
    ASRock J3455-ITX
    16GB DDR3L-1333
    3x WD green 3TB
    1x 60GB BOOT-SSD
    OMV 6.x
    TVHeadend 4.3.xx
    Phillips PUS8546
    Kodi 21 Beta (maven)
    diverse
    Raspberry Pi
    LibreElec 9.x
  • Hey,
    soweit ich weiß brauchst du das mit hasLcd nicht mehr machen. Aber egal....
    Erstmal würd ich schauen, ob der LCDd auch läuft
    ps -ef | grep -i lcd
    Falls der Daemon nicht läuft kannst du ihn zu Testzwecken mal von Hand starten, mit -c kannst du ihm die /etc/LCDd.conf mit übergeben.
    Weiterhin würd ich mal auf imonlcd wechseln, und in der entsprechenden Section die Werte anpassen. Dazu musst du mal ein
    lsusb
    ausführen und das Ergebnis in der LCDd.conf anpassen.
    ## Soundgraph iMON LCD ##
    [imonlcd]
    # Specify which iMon protocol should be used [legal: 0=15c2:ffdc device,
    # 1=15c2:0038 device; default: 0]
    Protocol=0
    Und letztlich noch das Addon LCDproc installieren, wo man auch nochmal paar Werte ändern kann.
    HIER übrigens noch die Doku zu LCDproc
    Bin leider nicht zuhause, sodass ich dir nicht alle Infos so aus dem Kopf geben kann ;)
  • Hallo
    Schonmal vielen dank für die Hife
    Habe mal auf die schnelle die Sachen geändert, aber noch kein erfolg.
    Quellcode
    bekomme dieses Ergebniss
    Aber leider weiß ich jetzt nicht ob das jetzt gut oder schlecht ist
    1896 1883 0 18:09 pts/0 00:00:00 grep --color=auto -i lcd
    Bei lsusb
    Bus 004 Device 003: ID 15c2:0044 SoundGraph Inc.
    Die Werte habe ich in die LCDd.conf
    Sieht dan nun so aus
    [imonlcd]
    # [legal: 0, 1; default: 0]
    # Choose 0 for 15c2:ffdc device,
    # Choose 1 for 15c2:0044 device
    Protocol=1
    mfg
  • OK schon mal vielen dank
    Bekomme diese Meldung
    LCDd 0.5.5, LCDproc Protocol 0.3
    Part of the LCDproc suite
    Copyright (C) 1998-2010 William Ferrell, Selene Scriven
    and many other contributors
    This program is free software; you can redistribute it and/or
    modify it under the terms of the GNU General Public License
    as published by the Free Software Foundation; either version 2
    of the License, or (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program; if not, write to the Free Software Foundation,
    Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
    Dann habe ich nochmal das ausgeführt
    und bekomme die Meldung
    2203 2187 0 19:26 pts/0 00:00:00 grep --color=auto -i lcd
